ASoC: wm8993: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Mark Brown
 sound/soc/codecs/wm8993.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/wm8993.c b/sound/soc/codecs/wm8993.c
index 8a8db86..bc9e042 100644
--- a/sound/soc/codecs/wm8993.c
+++ b/sound/soc/codecs/wm8993.c
@@ -628,11 +628,10 @@ static const DECLARE_TLV_DB_SCALE(sidetone_tlv, -3600, 300, 0);
 static const DECLARE_TLV_DB_SCALE(drc_comp_threash, -4500, 75, 0);
 static const DECLARE_TLV_DB_SCALE(drc_comp_amp, -2250, 75, 0);
 static const DECLARE_TLV_DB_SCALE(drc_min_tlv, -1800, 600, 0);
-static const unsigned int drc_max_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(drc_max_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(1200, 600, 0),
-	3, 3, TLV_DB_SCALE_ITEM(3600, 0, 0),
+	3, 3, TLV_DB_SCALE_ITEM(3600, 0, 0)
 static const DECLARE_TLV_DB_SCALE(drc_qr_tlv, 1200, 600, 0);
 static const DECLARE_TLV_DB_SCALE(drc_startup_tlv, -1800, 300, 0);
 static const DECLARE_TLV_DB_SCALE(eq_tlv, -1200, 100, 0);
BtrLinux
Privacy Overview
