sound/soc/codecs/wm9081.c | 7 +++----
1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/wm9081.c b/sound/soc/codecs/wm9081.c
index 8a8b1c0..5740cab 100644
--- a/sound/soc/codecs/wm9081.c
+++ b/sound/soc/codecs/wm9081.c
@@ -243,13 +243,12 @@ static int wm9081_reset(struct regmap *map)
static const DECLARE_TLV_DB_SCALE(drc_in_tlv, -4500, 75, 0);
static const DECLARE_TLV_DB_SCALE(drc_out_tlv, -2250, 75, 0);
static const DECLARE_TLV_DB_SCALE(drc_min_tlv, -1800, 600, 0);
-static unsigned int drc_max_tlv[] = {
- TLV_DB_RANGE_HEAD(4),
+static const DECLARE_TLV_DB_RANGE(drc_max_tlv,
0, 0, TLV_DB_SCALE_ITEM(1200, 0, 0),
1, 1, TLV_DB_SCALE_ITEM(1800, 0, 0),
2, 2, TLV_DB_SCALE_ITEM(2400, 0, 0),
- 3, 3, TLV_DB_SCALE_ITEM(3600, 0, 0),
+ 3, 3, TLV_DB_SCALE_ITEM(3600, 0, 0)
static const DECLARE_TLV_DB_SCALE(drc_qr_tlv, 1200, 600, 0);
static const DECLARE_TLV_DB_SCALE(drc_startup_tlv, -300, 50, 0); |
