sound/soc/codecs/wm8962.c | 14 ++++++--------
1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/sound/soc/codecs/wm8962.c b/sound/soc/codecs/wm8962.c
index c5748fd..b618da9 100644
--- a/sound/soc/codecs/wm8962.c
+++ b/sound/soc/codecs/wm8962.c
@@ -1456,14 +1456,13 @@ static int wm8962_reset(struct wm8962_priv *wm8962)
static const DECLARE_TLV_DB_SCALE(inpga_tlv, -2325, 75, 0);
static const DECLARE_TLV_DB_SCALE(mixin_tlv, -1500, 300, 0);
-static const unsigned int mixinpga_tlv[] = {
- TLV_DB_RANGE_HEAD(5),
+static const DECLARE_TLV_DB_RANGE(mixinpga_tlv,
0, 1, TLV_DB_SCALE_ITEM(0, 600, 0),
2, 2, TLV_DB_SCALE_ITEM(1300, 1300, 0),
3, 4, TLV_DB_SCALE_ITEM(1800, 200, 0),
5, 5, TLV_DB_SCALE_ITEM(2400, 0, 0),
- 6, 7, TLV_DB_SCALE_ITEM(2700, 300, 0),
+ 6, 7, TLV_DB_SCALE_ITEM(2700, 300, 0)
static const DECLARE_TLV_DB_SCALE(beep_tlv, -9600, 600, 1);
static const DECLARE_TLV_DB_SCALE(digital_tlv, -7200, 75, 1);
static const DECLARE_TLV_DB_SCALE(st_tlv, -3600, 300, 0);
@@ -1471,11 +1470,10 @@ static const DECLARE_TLV_DB_SCALE(inmix_tlv, -600, 600, 0);
static const DECLARE_TLV_DB_SCALE(bypass_tlv, -1500, 300, 0);
static const DECLARE_TLV_DB_SCALE(out_tlv, -12100, 100, 1);
static const DECLARE_TLV_DB_SCALE(hp_tlv, -700, 100, 0);
-static const unsigned int classd_tlv[] = {
- TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(classd_tlv,
0, 6, TLV_DB_SCALE_ITEM(0, 150, 0),
- 7, 7, TLV_DB_SCALE_ITEM(1200, 0, 0),
+ 7, 7, TLV_DB_SCALE_ITEM(1200, 0, 0)
static const DECLARE_TLV_DB_SCALE(eq_tlv, -1200, 100, 0);
static int wm8962_dsp2_write_config(struct snd_soc_codec *codec) |
