ASoC: da7210: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Adam Thomson
Signed-off-by: Mark Brown
 sound/soc/codecs/da7210.c | 22 +++++++++-------------
 1 file changed, 9 insertions(+), 13 deletions(-)
diff --git a/sound/soc/codecs/da7210.c b/sound/soc/codecs/da7210.c
index 21810e5..18ecdf3 100644
--- a/sound/soc/codecs/da7210.c
+++ b/sound/soc/codecs/da7210.c
@@ -267,33 +267,29 @@ enum clk_src {
  * Reserved area are considered as "mute".
-static const unsigned int hp_out_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(hp_out_tlv,
 	0x0, 0x10, TLV_DB_SCALE_ITEM(TLV_DB_GAIN_MUTE, 0, 1),
 	/* -54 dB to +15 dB */
-	0x11, 0x3f, TLV_DB_SCALE_ITEM(-5400, 150, 0),
+	0x11, 0x3f, TLV_DB_SCALE_ITEM(-5400, 150, 0)
-static const unsigned int lineout_vol_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(lineout_vol_tlv,
 	/* -54dB to 15dB */
-static const unsigned int mono_vol_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(mono_vol_tlv,
 	0x0, 0x2, TLV_DB_SCALE_ITEM(-1800, 0, 1),
 	/* -18dB to 6dB */
 	0x3, 0x7, TLV_DB_SCALE_ITEM(-1800, 600, 0)
-static const unsigned int aux1_vol_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(aux1_vol_tlv,
 	/* -48dB to 21dB */
 	0x11, 0x3f, TLV_DB_SCALE_ITEM(-4800, 150, 0)
 static const DECLARE_TLV_DB_SCALE(eq_gain_tlv, -1050, 150, 0);
 static const DECLARE_TLV_DB_SCALE(adc_eq_master_gain_tlv, -1800, 600, 1);
