ASoC: cs42l73: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Brian Austin
Signed-off-by: Mark Brown
 sound/soc/codecs/cs42l73.c | 14 ++++++--------
 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/sound/soc/codecs/cs42l73.c b/sound/soc/codecs/cs42l73.c
index b7853b9..15ba377 100644
--- a/sound/soc/codecs/cs42l73.c
+++ b/sound/soc/codecs/cs42l73.c
@@ -253,11 +253,10 @@ static bool cs42l73_readable_register(struct device *dev, unsigned int reg)
-static const unsigned int hpaloa_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(hpaloa_tlv,
 	0, 13, TLV_DB_SCALE_ITEM(-7600, 200, 0),
-	14, 75, TLV_DB_SCALE_ITEM(-4900, 100, 0),
+	14, 75, TLV_DB_SCALE_ITEM(-4900, 100, 0)
 static DECLARE_TLV_DB_SCALE(adc_boost_tlv, 0, 2500, 0);
@@ -267,11 +266,10 @@ static DECLARE_TLV_DB_SCALE(ipd_tlv, -9600, 100, 0);
 static DECLARE_TLV_DB_SCALE(micpga_tlv, -600, 50, 0);
-static const unsigned int limiter_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(limiter_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(-3000, 600, 0),
-	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0),
+	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0)
 static const DECLARE_TLV_DB_SCALE(attn_tlv, -6300, 100, 1);
