sound/soc/codecs/da7213.c | 15 ++++++---------
1 file changed, 6 insertions(+), 9 deletions(-)
diff --git a/sound/soc/codecs/da7213.c b/sound/soc/codecs/da7213.c
index 238e48a..c2358a9 100644
--- a/sound/soc/codecs/da7213.c
+++ b/sound/soc/codecs/da7213.c
@@ -28,27 +28,24 @@
/* Gain and Volume */
-static const unsigned int aux_vol_tlv[] = {
- TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(aux_vol_tlv,
/* -54dB */
0x0, 0x11, TLV_DB_SCALE_ITEM(-5400, 0, 0),
/* -52.5dB to 15dB */
0x12, 0x3f, TLV_DB_SCALE_ITEM(-5250, 150, 0)
-static const unsigned int digital_gain_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(digital_gain_tlv,
0x0, 0x07, TLV_DB_SCALE_ITEM(TLV_DB_GAIN_MUTE, 0, 1),
/* -78dB to 12dB */
0x08, 0x7f, TLV_DB_SCALE_ITEM(-7800, 75, 0)
-static const unsigned int alc_analog_gain_tlv[] = {
+static const DECLARE_TLV_DB_RANGE(alc_analog_gain_tlv,
0x0, 0x0, TLV_DB_SCALE_ITEM(TLV_DB_GAIN_MUTE, 0, 1),
/* 0dB to 36dB */
0x01, 0x07, TLV_DB_SCALE_ITEM(0, 600, 0)
static const DECLARE_TLV_DB_SCALE(mic_vol_tlv, -600, 600, 0);
static const DECLARE_TLV_DB_SCALE(mixin_gain_tlv, -450, 150, 0); |
