ASoC: cs42l56: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Brian Austin
Signed-off-by: Mark Brown
 sound/soc/codecs/cs42l56.c | 21 +++++++++------------
 1 file changed, 9 insertions(+), 12 deletions(-)
diff --git a/sound/soc/codecs/cs42l56.c b/sound/soc/codecs/cs42l56.c
index 1e11ba4..e88a559 100644
--- a/sound/soc/codecs/cs42l56.c
+++ b/sound/soc/codecs/cs42l56.c
@@ -185,21 +185,18 @@ static DECLARE_TLV_DB_SCALE(tone_tlv, -1050, 150, 0);
 static DECLARE_TLV_DB_SCALE(preamp_tlv, 0, 1000, 0);
 static DECLARE_TLV_DB_SCALE(pga_tlv, -600, 50, 0);
-static const unsigned int ngnb_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(ngnb_tlv,
 	0, 1, TLV_DB_SCALE_ITEM(-8200, 600, 0),
-	2, 5, TLV_DB_SCALE_ITEM(-7600, 300, 0),
-static const unsigned int ngb_tlv[] = {
+	2, 5, TLV_DB_SCALE_ITEM(-7600, 300, 0)
+static const DECLARE_TLV_DB_RANGE(ngb_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(-6400, 600, 0),
-	3, 7, TLV_DB_SCALE_ITEM(-4600, 300, 0),
-static const unsigned int alc_tlv[] = {
+	3, 7, TLV_DB_SCALE_ITEM(-4600, 300, 0)
+static const DECLARE_TLV_DB_RANGE(alc_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(-3000, 600, 0),
-	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0),
+	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0)
 static const char * const beep_config_text[] = {
 	"Off", "Single", "Multiple", "Continuous"
BtrLinux
Privacy Overview
