ASoC: cs42l52: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE
Author: Lars-Peter Clausen <lars@metafoo.de>
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
-	TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
Signed-off-by: Lars-Peter Clausen
Acked-by: Brian Austin
Signed-off-by: Mark Brown
 sound/soc/codecs/cs42l52.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/soc/codecs/cs42l52.c b/sound/soc/codecs/cs42l52.c
index 4de52c9..b4b4dc6 100644
--- a/sound/soc/codecs/cs42l52.c
+++ b/sound/soc/codecs/cs42l52.c
@@ -196,11 +196,10 @@ static DECLARE_TLV_DB_SCALE(mix_tlv, -50, 50, 0);
 static DECLARE_TLV_DB_SCALE(beep_tlv, -56, 200, 0);
-static const unsigned int limiter_tlv[] = {
-	TLV_DB_RANGE_HEAD(2),
+static const DECLARE_TLV_DB_RANGE(limiter_tlv,
 	0, 2, TLV_DB_SCALE_ITEM(-3000, 600, 0),
-	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0),
+	3, 7, TLV_DB_SCALE_ITEM(-1200, 300, 0)
 static const char * const cs42l52_adca_text[] = {
 	"Input1A", "Input2A", "Input3A", "Input4A", "PGA Input Left"};
