drivers/mmc/host: use ERR_CAST
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)).  The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
(http://coccinelle.lip6.fr/)
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
Signed-off-by: Julia Lawall
Cc:
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/mmc/host/sdhci-pci.c | 2 +-
diff --git a/drivers/mmc/host/sdhci-pci.c b/drivers/mmc/host/sdhci-pci.c
index 6701af6..65483fd 100644
--- a/drivers/mmc/host/sdhci-pci.c
+++ b/drivers/mmc/host/sdhci-pci.c
@@ -628,7 +628,7 @@ static struct sdhci_pci_slot * __devinit sdhci_pci_probe_slot(
 	host = sdhci_alloc_host(&pdev->dev, sizeof(struct sdhci_pci_slot));
 	if (IS_ERR(host)) {
 		dev_err(&pdev->dev, "cannot allocate host\n");
-		return ERR_PTR(PTR_ERR(host));
+		return ERR_CAST(host);
 	slot = sdhci_priv(host);
BtrLinux
Privacy Overview
