sound: Add missing spin_unlock
Add a spin_unlock missing on the error path.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* spin_lock(E1,...);
<+... when != E1
if (...) {
... when != E1
* return ...;
* spin_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
sound/mips/au1x00.c | 1 +
sound/oss/dmasound/dmasound_atari.c | 5 +++--
2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/sound/mips/au1x00.c b/sound/mips/au1x00.c
index 3e763d6..446cf97 100644
--- a/sound/mips/au1x00.c
+++ b/sound/mips/au1x00.c
@@ -516,6 +516,7 @@ get the interrupt driven case to work efficiently */
break;
if (i == 0x5000) {
printk(KERN_ERR "au1000 AC97: AC97 command read timeout\n");
+ spin_unlock(&au1000->ac97_lock);
return 0;
diff --git a/sound/oss/dmasound/dmasound_atari.c b/sound/oss/dmasound/dmasound_atari.c
index 1f47741..13c2144 100644
--- a/sound/oss/dmasound/dmasound_atari.c
+++ b/sound/oss/dmasound/dmasound_atari.c
@@ -1277,7 +1277,7 @@ static irqreturn_t AtaInterrupt(int irq, void *dummy)
* (almost) like on the TT.
write_sq_ignore_int = 0;
- return IRQ_HANDLED;
+ goto out;
if (!write_sq.active) {
@@ -1285,7 +1285,7 @@ static irqreturn_t AtaInterrupt(int irq, void *dummy)
* the sq variables, so better don't do anything here.
WAKE_UP(write_sq.sync_queue);
+ goto out;
/* Probably ;) one frame is finished. Well, in fact it may be that a
@@ -1322,6 +1322,7 @@ static irqreturn_t AtaInterrupt(int irq, void *dummy)
/* We are not playing after AtaPlay(), so there
is nothing to play any more. Wake up a process
waiting for audio output to drain. */
+out:
spin_unlock(&dmasound.lock);
return IRQ_HANDLED;
break;
if (i == 0x5000) {
return 0;
+ goto out;
+ goto out;
+out:
return IRQ_HANDLED;
