drivers/char/vt.c: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/char/vt.c | 10 +++-------
1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/char/vt.c b/drivers/char/vt.c
index bd1d116..7cdb6ee 100644
--- a/drivers/char/vt.c
+++ b/drivers/char/vt.c
@@ -3967,13 +3967,9 @@ static int con_font_set(struct vc_data *vc, struct console_font_op *op)
font.charcount = op->charcount;
font.height = op->height;
font.width = op->width;
- font.data = kmalloc(size, GFP_KERNEL);
- if (!font.data)
- return -ENOMEM;
- if (copy_from_user(font.data, op->data, size)) {
- kfree(font.data);
- return -EFAULT;
+ font.data = memdup_user(op->data, size);
+ if (IS_ERR(font.data))
+ return PTR_ERR(font.data);
acquire_console_sem();
if (vc->vc_sw->con_font_set)
rc = vc->vc_sw->con_font_set(vc, &font, op->flags); |
- if (!font.data)
- return -ENOMEM;
- kfree(font.data);
- return -EFAULT;
