drivers/message/i2o/i2o_config.c: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/message/i2o/i2o_config.c | 11 +++--------
1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/message/i2o/i2o_config.c b/drivers/message/i2o/i2o_config.c
index d33693c..c4b117f 100644
--- a/drivers/message/i2o/i2o_config.c
+++ b/drivers/message/i2o/i2o_config.c
@@ -186,14 +186,9 @@ static int i2o_cfg_parms(unsigned long arg, unsigned int type)
if (!dev)
return -ENXIO;
- ops = kmalloc(kcmd.oplen, GFP_KERNEL);
- if (!ops)
- return -ENOMEM;
- if (copy_from_user(ops, kcmd.opbuf, kcmd.oplen)) {
- kfree(ops);
- return -EFAULT;
+ ops = memdup_user(kcmd.opbuf, kcmd.oplen);
+ if (IS_ERR(ops))
+ return PTR_ERR(ops);
* It's possible to have a _very_ large table |
if (!dev)
return -ENXIO;
- if (!ops)
- return -ENOMEM;
- kfree(ops);
- return -EFAULT;
+ if (IS_ERR(ops))
