xen-netfront: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e, func, da;
-init_timer (&e);
+setup_timer (&e, func, da);
-e.data = da;
-e.function = func;
Signed-off-by: Vaishali Thakkar
Signed-off-by: David S. Miller
 drivers/net/xen-netfront.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/net/xen-netfront.c b/drivers/net/xen-netfront.c
index 3f45afd..10a087a 100644
--- a/drivers/net/xen-netfront.c
+++ b/drivers/net/xen-netfront.c
@@ -1560,9 +1560,8 @@ static int xennet_init_queue(struct netfront_queue *queue)
 	spin_lock_init(&queue->tx_lock);
 	spin_lock_init(&queue->rx_lock);
-	init_timer(&queue->rx_refill_timer);
-	queue->rx_refill_timer.data = (unsigned long)queue;
-	queue->rx_refill_timer.function = rx_refill_timeout;
+	setup_timer(&queue->rx_refill_timer, rx_refill_timeout,
+		    (unsigned long)queue);
 	snprintf(queue->name, sizeof(queue->name), "%s-q%u",
 		 queue->info->netdev->name, queue->id);
BtrLinux
Privacy Overview
