ethernet/intel: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e1, e2, e3, e4, a, b;
-init_timer(&e1);
+setup_timer(&e1, a, b);
... when != a = e2
    when != b = e3
-e1.function = a;
... when != b = e4
-e1.data = b;
Signed-off-by: Vaishali Thakkar
Signed-off-by: David S. Miller
 drivers/net/ethernet/intel/e100.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/intel/e100.c b/drivers/net/ethernet/intel/e100.c
index 35357ae..d2657a4 100644
--- a/drivers/net/ethernet/intel/e100.c
+++ b/drivers/net/ethernet/intel/e100.c
@@ -2922,9 +2922,7 @@ static int e100_probe(struct pci_dev *pdev, const struct pci_device_id *ent)
 	pci_set_master(pdev);
-	init_timer(&nic->watchdog);
-	nic->watchdog.function = e100_watchdog;
-	nic->watchdog.data = (unsigned long)nic;
+	setup_timer(&nic->watchdog, e100_watchdog, (unsigned long)nic);
 	INIT_WORK(&nic->tx_timeout_task, e100_tx_timeout_task);
