watchdog: sp805_wdt.c: use clk_prepare_enable and clk_disable_unprepare
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Clk_prepare_enable and clk_disable_unprepare combine clk_prepare and
clk_enable, and clk_disable and clk_unprepare.  They make the code more
concise, and ensure that clk_unprepare is called when clk_enable fails.
A simplified version of the semantic patch that introduces calls to these
functions is as follows: (http://coccinelle.lip6.fr/)
expression e;
- clk_prepare(e);
- clk_enable(e);
+ clk_prepare_enable(e);
expression e;
- clk_disable(e);
- clk_unprepare(e);
+ clk_disable_unprepare(e);
Signed-off-by: Julia Lawall
Acked-by: Viresh Kumar
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/sp805_wdt.c | 11 ++---------
 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c
index 76c73cb..8872642 100644
--- a/drivers/watchdog/sp805_wdt.c
+++ b/drivers/watchdog/sp805_wdt.c
@@ -130,16 +130,10 @@ static int wdt_config(struct watchdog_device *wdd, bool ping)
 	int ret;
 	if (!ping) {
-		ret = clk_prepare(wdt->clk);
-		if (ret) {
-			dev_err(&wdt->adev->dev, "clock prepare fail");
-			return ret;
-		ret = clk_enable(wdt->clk);
+		ret = clk_prepare_enable(wdt->clk);
 		if (ret) {
 			dev_err(&wdt->adev->dev, "clock enable fail");
-			clk_unprepare(wdt->clk);
 			return ret;
@@ -190,8 +184,7 @@ static int wdt_disable(struct watchdog_device *wdd)
 	readl_relaxed(wdt->base + WDTLOCK);
 	spin_unlock(&wdt->lock);
-	clk_disable(wdt->clk);
+	clk_disable_unprepare(wdt->clk);
 	return 0;
BtrLinux
Privacy Overview
