drivers/tty/serial/amba-pl0{10,11}.c: use clk_prepare_enable and clk_disable_unprepare
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Clk_prepare_enable and clk_disable_unprepare combine clk_prepare and
clk_enable, and clk_disable and clk_unprepare. The9 make the code more
concise, and ensure that clk_unprepare is called when clk_enable fails.
A simplified version of the semantic patch that introduces calls to these
functions is as follows: (http://coccinelle.lip6.fr/)
expression e;
- clk_prepare(e);
- clk_enable(e);
+ clk_prepare_enable(e);
expression e;
- clk_disable(e);
- clk_unprepare(e);
+ clk_disable_unprepare(e);
Signed-off-by: Julia Lawall
drivers/tty/serial/amba-pl010.c | 15 ++++-----------
drivers/tty/serial/amba-pl011.c | 15 ++++-----------
2 files changed, 8 insertions(+), 22 deletions(-)
diff --git a/drivers/tty/serial/amba-pl010.c b/drivers/tty/serial/amba-pl010.c
index 0d91a54..22317dd 100644
--- a/drivers/tty/serial/amba-pl010.c
+++ b/drivers/tty/serial/amba-pl010.c
@@ -312,16 +312,12 @@ static int pl010_startup(struct uart_port *port)
struct uart_amba_port *uap = (struct uart_amba_port *)port;
int retval;
- retval = clk_prepare(uap->clk);
- if (retval)
- goto out;
* Try to enable the clock producer.
- retval = clk_enable(uap->clk);
+ retval = clk_prepare_enable(uap->clk);
if (retval)
- goto clk_unprep;
+ goto out;
uap->port.uartclk = clk_get_rate(uap->clk);
@@ -346,9 +342,7 @@ static int pl010_startup(struct uart_port *port)
return 0;
clk_dis:
- clk_disable(uap->clk);
- clk_unprep:
- clk_unprepare(uap->clk);
+ clk_disable_unprepare(uap->clk);
out:
return retval;
@@ -375,8 +369,7 @@ static void pl010_shutdown(struct uart_port *port)
* Shut down the clock producer
static void
diff --git a/drivers/tty/serial/amba-pl011.c b/drivers/tty/serial/amba-pl011.c
index 92b1ac8..3322023 100644
--- a/drivers/tty/serial/amba-pl011.c
+++ b/drivers/tty/serial/amba-pl011.c
@@ -1324,16 +1324,12 @@ static int pl011_startup(struct uart_port *port)
"could not set default pins\n");
- if (retval)
- goto out;
if (retval)
- goto clk_unprep;
+ goto out;
@@ -1411,9 +1407,7 @@ static int pl011_startup(struct uart_port *port)
return 0;
clk_dis:
- clk_unprep:
out:
return retval;
@@ -1473,8 +1467,7 @@ static void pl011_shutdown(struct uart_port *port)
/* Optionally let pins go into sleep states */
if (!IS_ERR(uap->pins_sleep)) {
retval = pinctrl_select_state(uap->pinctrl, uap->pins_sleep); |
int retval;
- if (retval)
- goto out;
if (retval)
- goto clk_unprep;
+ goto out;
return 0;
clk_dis:
- clk_unprep:
out:
return retval;
static void
- if (retval)
- goto out;
if (retval)
- goto clk_unprep;
+ goto out;
return 0;
clk_dis:
- clk_unprep:
out:
return retval;
