watchdog: simplify platform_get_resource_byname/devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource_byname when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,e,e1;
expression ret != 0;
identifier l;
res = platform_get_resource_byname(...);
- if (res == NULL) { ... \(goto l;\|return ret;\) }
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Reviewed-by: Guenter Roeck
Signed-off-by: Wim Van Sebroeck
drivers/watchdog/ar7_wdt.c | 5 -----
1 file changed, 5 deletions(-)
diff --git a/drivers/watchdog/ar7_wdt.c b/drivers/watchdog/ar7_wdt.c
index 2f3cc8f..b3709f9 100644
--- a/drivers/watchdog/ar7_wdt.c
+++ b/drivers/watchdog/ar7_wdt.c
@@ -280,11 +280,6 @@ static int ar7_wdt_probe(struct platform_device *pdev)
ar7_regs_wdt =
platform_get_resource_byname(pdev, IORESOURCE_MEM, "regs");
- if (!ar7_regs_wdt) {
- pr_err("could not get registers resource\n");
- return -ENODEV;
ar7_wdt = devm_ioremap_resource(&pdev->dev, ar7_regs_wdt);
if (IS_ERR(ar7_wdt))
return PTR_ERR(ar7_wdt); |
ar7_regs_wdt =
- return -ENODEV;
