mtd: fsmc_nand: simplify platform_get_resource_byname/devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource_byname when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,e,e1;
expression ret != 0;
identifier l;
res = platform_get_resource_byname(...);
- if (res == NULL) { ... \(goto l;\|return ret;\) }
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
drivers/mtd/nand/fsmc_nand.c | 12 ------------
1 file changed, 12 deletions(-)
diff --git a/drivers/mtd/nand/fsmc_nand.c b/drivers/mtd/nand/fsmc_nand.c
index 2a3b1b9..3dc1a75 100644
--- a/drivers/mtd/nand/fsmc_nand.c
+++ b/drivers/mtd/nand/fsmc_nand.c
@@ -958,9 +958,6 @@ static int __init fsmc_nand_probe(struct platform_device *pdev)
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "nand_data");
- if (!res)
- return -EINVAL;
host->data_va = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(host->data_va))
return PTR_ERR(host->data_va);
@@ -968,25 +965,16 @@ static int __init fsmc_nand_probe(struct platform_device *pdev)
host->data_pa = (dma_addr_t)res->start;
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "nand_addr");
- if (!res)
- return -EINVAL;
host->addr_va = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(host->addr_va))
return PTR_ERR(host->addr_va);
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "nand_cmd");
- if (!res)
- return -EINVAL;
host->cmd_va = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(host->cmd_va))
return PTR_ERR(host->cmd_va);
res = platform_get_resource_byname(pdev, IORESOURCE_MEM, "fsmc_regs");
- if (!res)
- return -EINVAL;
host->regs_va = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(host->regs_va))
return PTR_ERR(host->regs_va); |
- if (!res)
- return -EINVAL;
- if (!res)
- return -EINVAL;
- if (!res)
- return -EINVAL;
- if (!res)
- return -EINVAL;
