watchdog: s3c2410_wdt: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Reviewed-by: Guenter Roeck
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/s3c2410_wdt.c | 6 +-----
 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/watchdog/s3c2410_wdt.c b/drivers/watchdog/s3c2410_wdt.c
index 43d2807..23aad7c 100644
--- a/drivers/watchdog/s3c2410_wdt.c
+++ b/drivers/watchdog/s3c2410_wdt.c
@@ -353,11 +353,6 @@ static int s3c2410wdt_probe(struct platform_device *pdev)
 	wdt->dev = &pdev->dev;
 	spin_lock_init(&wdt->lock);
 	wdt->wdt_device = s3c2410_wdd;
-	wdt_mem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (wdt_mem == NULL) {
-		dev_err(dev, "no memory resource specified\n");
-		return -ENOENT;
 	wdt_irq = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
 	if (wdt_irq == NULL) {
@@ -367,6 +362,7 @@ static int s3c2410wdt_probe(struct platform_device *pdev)
 	/* get the memory region for the watchdog timer */
+	wdt_mem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	wdt->reg_base = devm_ioremap_resource(dev, wdt_mem);
 	if (IS_ERR(wdt->reg_base)) {
 		ret = PTR_ERR(wdt->reg_base);
BtrLinux
Privacy Overview
