watchdog: ts72xx_wdt: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Reviewed-by: Guenter Roeck
Signed-off-by: Wim Van Sebroeck
drivers/watchdog/ts72xx_wdt.c | 10 ----------
1 file changed, 10 deletions(-)
diff --git a/drivers/watchdog/ts72xx_wdt.c b/drivers/watchdog/ts72xx_wdt.c
index 4da59b4..42913f1 100644
--- a/drivers/watchdog/ts72xx_wdt.c
+++ b/drivers/watchdog/ts72xx_wdt.c
@@ -403,21 +403,11 @@ static int ts72xx_wdt_probe(struct platform_device *pdev)
r1 = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- if (!r1) {
- dev_err(&pdev->dev, "failed to get memory resource\n");
- return -ENODEV;
wdt->control_reg = devm_ioremap_resource(&pdev->dev, r1);
if (IS_ERR(wdt->control_reg))
return PTR_ERR(wdt->control_reg);
r2 = platform_get_resource(pdev, IORESOURCE_MEM, 1);
- if (!r2) {
- return -ENODEV;
wdt->feed_reg = devm_ioremap_resource(&pdev->dev, r2);
if (IS_ERR(wdt->feed_reg))
return PTR_ERR(wdt->feed_reg); |
- if (!r1) {
- return -ENODEV;
- if (!r2) {
- return -ENODEV;
