video: fbdev-OMAP2: Deletion of unnecessary checks before the function call “i2c_put_adapter”
Author: Markus Elfring <elfring@users.sourceforge.net>
The i2c_put_adapter() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/omap2/displays-new/connector-dvi.c | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/video/fbdev/omap2/displays-new/connector-dvi.c b/drivers/video/fbdev/omap2/displays-new/connector-dvi.c
index 2dfb6e5..3d38e47 100644
--- a/drivers/video/fbdev/omap2/displays-new/connector-dvi.c
+++ b/drivers/video/fbdev/omap2/displays-new/connector-dvi.c
@@ -262,8 +262,7 @@ static int dvic_probe_pdata(struct platform_device *pdev)
 	in = omap_dss_find_output(pdata->source);
 	if (in == NULL) {
-		if (ddata->i2c_adapter)
-			i2c_put_adapter(ddata->i2c_adapter);
+		i2c_put_adapter(ddata->i2c_adapter);
 		dev_err(&pdev->dev, "Failed to find video source\n");
 		return -EPROBE_DEFER;
@@ -352,8 +351,7 @@ static int dvic_probe(struct platform_device *pdev)
 err_reg:
 	omap_dss_put_device(ddata->in);
 	return r;
@@ -371,8 +369,7 @@ static int __exit dvic_remove(struct platform_device *pdev)
 	omap_dss_put_device(in);
 	return 0;
BtrLinux
Privacy Overview
