drm/exynos/ipp: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Propagate the returned error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Inki Dae
drivers/gpu/drm/exynos/exynos_drm_ipp.c | 3 +++
1 file changed, 3 insertions(+)
diff --git a/drivers/gpu/drm/exynos/exynos_drm_ipp.c b/drivers/gpu/drm/exynos/exynos_drm_ipp.c
index 00d74b1..d5ad17d 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_ipp.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_ipp.c
@@ -426,18 +426,21 @@ int exynos_drm_ipp_set_property(struct drm_device *drm_dev, void *data,
c_node->start_work = ipp_create_cmd_work();
if (IS_ERR(c_node->start_work)) {
DRM_ERROR("failed to create start work.\n");
+ ret = PTR_ERR(c_node->start_work);
goto err_remove_id;
c_node->stop_work = ipp_create_cmd_work();
if (IS_ERR(c_node->stop_work)) {
DRM_ERROR("failed to create stop work.\n");
+ ret = PTR_ERR(c_node->stop_work);
goto err_free_start;
c_node->event_work = ipp_create_event_work();
if (IS_ERR(c_node->event_work)) {
DRM_ERROR("failed to create event work.\n");
+ ret = PTR_ERR(c_node->event_work);
goto err_free_stop;
goto err_remove_id;
goto err_free_stop;
