V4L/DVB: drivers/staging/tm6000/tm6000-video.c: correct NULL test
Test the just-allocated value for NULL rather than some other value.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,y;
statement S;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
if ((x) == NULL) S
if (
-   y
+   x
       == NULL)
 S
Signed-off-by: Julia Lawall
Acked-by: Greg Kroah-Hartman
Signed-off-by: Mauro Carvalho Chehab
 drivers/staging/tm6000/tm6000-video.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/tm6000/tm6000-video.c b/drivers/staging/tm6000/tm6000-video.c
index 217721f..627b0dd 100644
--- a/drivers/staging/tm6000/tm6000-video.c
+++ b/drivers/staging/tm6000/tm6000-video.c
@@ -644,7 +644,7 @@ static int tm6000_prepare_isoc(struct tm6000_core *dev, unsigned int framesize)
 	dev->isoc_ctl.transfer_buffer = kmalloc(sizeof(void *)*num_bufs,
 				   GFP_KERNEL);
-	if (!dev->isoc_ctl.urb) {
+	if (!dev->isoc_ctl.transfer_buffer) {
 		tm6000_err("cannot allocate memory for usbtransfer\n");
 		kfree(dev->isoc_ctl.urb);
 		return -ENOMEM;
BtrLinux
Privacy Overview
