drivers/net: Correct NULL test
Test the value that was just allocated rather than the previously tested one.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r@
expression *x;
expression e;
identifier l;
if (x == NULL || ...) {
... when forall
return ...; }
... when != goto l;
when != x = e
when != &x
*x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ax88796.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ax88796.c b/drivers/net/ax88796.c
index 62d9c9c..1dd4403 100644
--- a/drivers/net/ax88796.c
+++ b/drivers/net/ax88796.c
@@ -921,7 +921,7 @@ static int ax_probe(struct platform_device *pdev)
size = (res->end - res->start) + 1;
ax->mem2 = request_mem_region(res->start, size, pdev->name);
- if (ax->mem == NULL) {
+ if (ax->mem2 == NULL) {
dev_err(&pdev->dev, "cannot reserve registers\n");
ret = -ENXIO;
goto exit_mem1; |
ret = -ENXIO;
goto exit_mem1;
