V4L/DVB (7035): drivers/media/common: Add missing video_device_release
Video_device_alloc returns the result of a kzalloc. In this case, the
value is stored in a local variable which is not copied elsewhere before
the point of the error return (video_register_device does not save its
first argument anywhere if it returns a negative value). Thus, a
video_device_release it needed before the error return.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2,x3;
int ret;
T E;
* E = video_device_alloc(...);
if (E == NULL) S
... when != video_device_release(...,(T1)E,...)
when != if (E != NULL) { ... video_device_release(...,(T1)E,...); ...}
when != x1 = (T1)E
when != E = x3;
when any
if (...) {
... when != video_device_release(...,(T2)E,...)
when != if (E != NULL) { ... video_device_release(...,(T2)E,...); ...}
when != x2 = (T2)E
* return;
* return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
CC: Oliver Endriss
CC: Michael Hunold
Signed-off-by: Mauro Carvalho Chehab
drivers/media/common/saa7146_fops.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/media/common/saa7146_fops.c b/drivers/media/common/saa7146_fops.c
index b40bf23..f0703d8 100644
--- a/drivers/media/common/saa7146_fops.c
+++ b/drivers/media/common/saa7146_fops.c
@@ -538,6 +538,7 @@ int saa7146_register_device(struct video_device **vid, struct saa7146_dev* dev,
// fixme: -1 should be an insmod parameter *for the extension* (like "video_nr");
if (video_register_device(vfd, type, -1) < 0) {
ERR(("cannot register v4l2 device. skipping.\n"));
+ video_device_release(vfd);
return -1;
return -1;
