arch/x86/ia32: use time_before, time_before_eq, etc.
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
#include
+ #include
[ mingo@elte.hu: merge to x86.git ]
Signed-off-by: Julia Lawall
Signed-off-by: Ingo Molnar
Signed-off-by: Thomas Gleixner
arch/x86/ia32/ia32_aout.c | 8 +++++---
1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/x86/ia32/ia32_aout.c b/arch/x86/ia32/ia32_aout.c
index f1a0f83..e4c1207 100644
--- a/arch/x86/ia32/ia32_aout.c
+++ b/arch/x86/ia32/ia32_aout.c
@@ -25,6 +25,7 @@
#include <linux/binfmts.h>
#include <linux/personality.h>
#include <linux/init.h>
+#include <linux/jiffies.h>
#include <asm/system.h>
#include <asm/uaccess.h>
@@ -359,13 +360,14 @@ static int load_aout_binary(struct linux_binprm *bprm, struct pt_regs *regs)
#ifdef WARN_OLD
static unsigned long error_time, error_time2;
if ((ex.a_text & 0xfff || ex.a_data & 0xfff) &&
- (N_MAGIC(ex) != NMAGIC) && (jiffies-error_time2) > 5*HZ) {
+ (N_MAGIC(ex) != NMAGIC) &&
+ time_after(jiffies, error_time2 + 5*HZ)) {
printk(KERN_NOTICE "executable not page aligned\n");
error_time2 = jiffies;
if ((fd_offset & ~PAGE_MASK) != 0 &&
- (jiffies - error_time) > 5*HZ) {
+ time_after(jiffies, error_time + 5*HZ)) {
printk(KERN_WARNING
"fd_offset is not page aligned. Please convert "
"program: %s\n",
@@ -484,7 +486,7 @@ static int load_aout_library(struct file *file)
#ifdef WARN_OLD
static unsigned long error_time;
- if ((jiffies-error_time) > 5*HZ) {
+ if (time_after(jiffies, error_time + 5*HZ)) {
printk(KERN_WARNING
"N_TXTOFF is not page aligned. Please convert "
"library: %s\n", |
@@ -25,6 +25,7 @@
#ifdef WARN_OLD
printk(KERN_WARNING
"program: %s\n",
#ifdef WARN_OLD
printk(KERN_WARNING
"library: %s\n",
