V4L/DVB (12478): ARRAY_SIZE changes
Author: Mauro Carvalho Chehab <mchehab@redhat.com>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
[mchehab@redhat.com: fix a merge conflict]
Signed-off-by: Stoyan Gaydarov
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/gspca/conex.c   | 2 +-
 drivers/media/video/gspca/etoms.c   | 4 ++--
 drivers/media/video/gspca/spca501.c | 2 +-
 drivers/media/video/gspca/spca506.c | 2 +-
 drivers/media/video/gspca/sunplus.c | 4 ++--
 drivers/media/video/gspca/zc3xx.c   | 2 +-
 drivers/media/video/tveeprom.c      | 4 ++--
 7 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/media/video/gspca/conex.c b/drivers/media/video/gspca/conex.c
index 8d48ea1..eca0035 100644
--- a/drivers/media/video/gspca/conex.c
+++ b/drivers/media/video/gspca/conex.c
@@ -820,7 +820,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	cam = &gspca_dev->cam;
 	cam->cam_mode = vga_mode;
-	cam->nmodes = sizeof vga_mode / sizeof vga_mode[0];
+	cam->nmodes = ARRAY_SIZE(vga_mode);
 	sd->brightness = BRIGHTNESS_DEF;
 	sd->contrast = CONTRAST_DEF;
diff --git a/drivers/media/video/gspca/etoms.c b/drivers/media/video/gspca/etoms.c
index 2c20d06..c1461e6 100644
--- a/drivers/media/video/gspca/etoms.c
+++ b/drivers/media/video/gspca/etoms.c
@@ -635,10 +635,10 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	sd->sensor = id->driver_info;
 	if (sd->sensor == SENSOR_PAS106) {
 		cam->cam_mode = sif_mode;
-		cam->nmodes = sizeof sif_mode / sizeof sif_mode[0];
+		cam->nmodes = ARRAY_SIZE(sif_mode);
 	} else {
 		gspca_dev->ctrl_dis = (1 << COLOR_IDX);
diff --git a/drivers/media/video/gspca/spca501.c b/drivers/media/video/gspca/spca501.c
index d48b27c..b74a342 100644
--- a/drivers/media/video/gspca/spca501.c
+++ b/drivers/media/video/gspca/spca501.c
@@ -1923,7 +1923,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	sd->subtype = id->driver_info;
 	sd->brightness = sd_ctrls[MY_BRIGHTNESS].qctrl.default_value;
 	sd->contrast = sd_ctrls[MY_CONTRAST].qctrl.default_value;
diff --git a/drivers/media/video/gspca/spca506.c b/drivers/media/video/gspca/spca506.c
index 3a0c893..a199298 100644
--- a/drivers/media/video/gspca/spca506.c
+++ b/drivers/media/video/gspca/spca506.c
@@ -286,7 +286,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 	sd->brightness = sd_ctrls[SD_BRIGHTNESS].qctrl.default_value;
 	sd->contrast = sd_ctrls[SD_CONTRAST].qctrl.default_value;
 	sd->colors = sd_ctrls[SD_COLOR].qctrl.default_value;
diff --git a/drivers/media/video/gspca/sunplus.c b/drivers/media/video/gspca/sunplus.c
index eabad47..e9481fa 100644
--- a/drivers/media/video/gspca/sunplus.c
+++ b/drivers/media/video/gspca/sunplus.c
@@ -841,7 +841,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 /*	case BRIDGE_SPCA504: */
 /*	case BRIDGE_SPCA536: */
+		cam->nmodes =ARRAY_SIZE(vga_mode);
 		break;
 	case BRIDGE_SPCA533:
 		cam->cam_mode = custom_mode;
@@ -852,7 +852,7 @@ static int sd_config(struct gspca_dev *gspca_dev,
 		break;
 	case BRIDGE_SPCA504C:
 		cam->cam_mode = vga_mode2;
-		cam->nmodes = sizeof vga_mode2 / sizeof vga_mode2[0];
+		cam->nmodes = ARRAY_SIZE(vga_mode2);
 		break;
diff --git a/drivers/media/video/gspca/zc3xx.c b/drivers/media/video/gspca/zc3xx.c
index 3d2756f..cdf3357 100644
--- a/drivers/media/video/gspca/zc3xx.c
+++ b/drivers/media/video/gspca/zc3xx.c
@@ -7574,7 +7574,7 @@ static int sd_get_jcomp(struct gspca_dev *gspca_dev,
 static const struct sd_desc sd_desc = {
 	.name = MODULE_NAME,
 	.ctrls = sd_ctrls,
-	.nctrls = sizeof sd_ctrls / sizeof sd_ctrls[0],
+	.nctrls = ARRAY_SIZE(sd_ctrls),
 	.config = sd_config,
 	.init = sd_init,
 	.start = sd_start,
diff --git a/drivers/media/video/tveeprom.c b/drivers/media/video/tveeprom.c
index ac02808..d533ea5 100644
--- a/drivers/media/video/tveeprom.c
+++ b/drivers/media/video/tveeprom.c
@@ -646,14 +646,14 @@ void tveeprom_hauppauge_analog(struct i2c_client *c, struct tveeprom *tvee,
 		tvee->has_radio = 1;
-	if (tuner1 < sizeof(hauppauge_tuner)/sizeof(struct HAUPPAUGE_TUNER)) {
+	if (tuner1 < ARRAY_SIZE(hauppauge_tuner)) {
 		tvee->tuner_type = hauppauge_tuner[tuner1].id;
 		t_name1 = hauppauge_tuner[tuner1].name;
 	} else {
 		t_name1 = "unknown";
-	if (tuner2 < sizeof(hauppauge_tuner)/sizeof(struct HAUPPAUGE_TUNER)) {
+	if (tuner2 < ARRAY_SIZE(hauppauge_tuner)) {
 		tvee->tuner2_type = hauppauge_tuner[tuner2].id;
 		t_name2 = hauppauge_tuner[tuner2].name;
 	} else {
BtrLinux
Privacy Overview
