ARRAY_SIZE changes
Author: Stoyan Gaydarov <sgayda2@uiuc.edu>
These changes were a direct result of using a semantic patch
More information can be found at http://www.emn.fr/x-info/coccinelle/
Signed-off-by: Stoyan Gaydarov
Signed-off-by: Jesper Nilsson
arch/cris/arch-v32/mach-a3/io.c | 2 +-
arch/cris/arch-v32/mach-fs/io.c | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/cris/arch-v32/mach-a3/io.c b/arch/cris/arch-v32/mach-a3/io.c
index c22f67e..090ceb9 100644
--- a/arch/cris/arch-v32/mach-a3/io.c
+++ b/arch/cris/arch-v32/mach-a3/io.c
@@ -36,7 +36,7 @@ struct crisv32_ioport crisv32_ioports[] = {
-#define NBR_OF_PORTS sizeof(crisv32_ioports)/sizeof(struct crisv32_ioport)
+#define NBR_OF_PORTS ARRAY_SIZE(crisv32_ioports)
struct crisv32_iopin crisv32_led_net0_green;
struct crisv32_iopin crisv32_led_net0_red;
diff --git a/arch/cris/arch-v32/mach-fs/io.c b/arch/cris/arch-v32/mach-fs/io.c
index cb6327b..a695866 100644
--- a/arch/cris/arch-v32/mach-fs/io.c
+++ b/arch/cris/arch-v32/mach-fs/io.c
@@ -52,7 +52,7 @@ struct crisv32_ioport crisv32_ioports[] = {
struct crisv32_iopin crisv32_led_net0_red; |
