V4L/DVB (10185): Use negated usb_endpoint_xfer_control, etc
This patch extends 134179823b3ca9c8b98e0631906459dbb022ff9b by using
usb_endpoint_xfer_control, usb_endpoint_xfer_isoc, usb_endpoint_xfer_bulk,
and usb_endpoint_xfer_int in the negated case as well.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ struct usb_endpoint_descriptor *epd; @@
- (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ !usb_endpoint_xfer_control(epd)
- (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_ISOC\|1\))
+ !usb_endpoint_xfer_isoc(epd)
- (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_BULK\|2\))
+ !usb_endpoint_xfer_bulk(epd)
- (usb_endpoint_type(epd) != \(USB_ENDPOINT_XFER_INT\|3\))
+ !usb_endpoint_xfer_int(epd)
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/em28xx/em28xx-cards.c       | 3 +--
 drivers/media/video/usbvideo/ibmcam.c           | 2 +-
 drivers/media/video/usbvideo/konicawc.c         | 2 +-
 drivers/media/video/usbvideo/ultracam.c         | 2 +-
 drivers/media/video/usbvision/usbvision-video.c | 3 +--
 5 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/media/video/em28xx/em28xx-cards.c b/drivers/media/video/em28xx/em28xx-cards.c
index 6d2e4a6..ef9bf00 100644
--- a/drivers/media/video/em28xx/em28xx-cards.c
+++ b/drivers/media/video/em28xx/em28xx-cards.c
@@ -1990,8 +1990,7 @@ static int em28xx_usb_probe(struct usb_interface *interface,
 		int check_interface = 1;
 		isoc_pipe = 1;
 		endpoint = &interface->cur_altsetting->endpoint[1].desc;
-		if (usb_endpoint_type(endpoint) !=
-		    USB_ENDPOINT_XFER_ISOC)
+		if (!usb_endpoint_xfer_isoc(endpoint))
 			check_interface = 0;
 		if (usb_endpoint_dir_out(endpoint))
diff --git a/drivers/media/video/usbvideo/ibmcam.c b/drivers/media/video/usbvideo/ibmcam.c
index f8d85dd..b085496 100644
--- a/drivers/media/video/usbvideo/ibmcam.c
+++ b/drivers/media/video/usbvideo/ibmcam.c
@@ -3779,7 +3779,7 @@ static int ibmcam_probe(struct usb_interface *intf, const struct usb_device_id *
 			err("Alternate settings have different endpoint addresses!");
 			return -ENODEV;
-		if (usb_endpoint_type(endpoint) != USB_ENDPOINT_XFER_ISOC) {
+		if (!usb_endpoint_xfer_isoc(endpoint)) {
 			err("Interface %d. has non-ISO endpoint!", ifnum);
 			return -ENODEV;
diff --git a/drivers/media/video/usbvideo/konicawc.c b/drivers/media/video/usbvideo/konicawc.c
index 90f0ce6..900ec21 100644
--- a/drivers/media/video/usbvideo/konicawc.c
+++ b/drivers/media/video/usbvideo/konicawc.c
@@ -823,7 +823,7 @@ static int konicawc_probe(struct usb_interface *intf, const struct usb_device_id
 			return -ENODEV;
 			    interface->desc.bInterfaceNumber);
 			return -ENODEV;
diff --git a/drivers/media/video/usbvideo/ultracam.c b/drivers/media/video/usbvideo/ultracam.c
index 839a082..fbd1b63 100644
--- a/drivers/media/video/usbvideo/ultracam.c
+++ b/drivers/media/video/usbvideo/ultracam.c
@@ -556,7 +556,7 @@ static int ultracam_probe(struct usb_interface *intf, const struct usb_device_id
 			return -ENODEV;
 			return -ENODEV;
diff --git a/drivers/media/video/usbvision/usbvision-video.c b/drivers/media/video/usbvision/usbvision-video.c
index 2be5e47..2622de0 100644
--- a/drivers/media/video/usbvision/usbvision-video.c
+++ b/drivers/media/video/usbvision/usbvision-video.c
@@ -1674,8 +1674,7 @@ static int __devinit usbvision_probe(struct usb_interface *intf,
 		interface = &dev->actconfig->interface[ifnum]->altsetting[0];
 	endpoint = &interface->endpoint[1].desc;
-	    USB_ENDPOINT_XFER_ISOC) {
 		err("%s: interface %d. has non-ISO endpoint!",
 		    __func__, ifnum);
 		err("%s: Endpoint attributes %d",
BtrLinux
Privacy Overview
