mm/page_alloc.c: eliminate NULL test and memset after alloc_bootmem
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b,
alloc_bootmem and related functions never return NULL and always return a
zeroed region of memory. Thus a NULL test or memset after calls to these
functions is unnecessary.
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\|alloc_bootmem_node\|alloc_bootmem_low_pages_node\|alloc_bootmem_pages_node\)(...)
... when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
... when != E
- memset(E,0,E1);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
mm/page_alloc.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/mm/page_alloc.c b/mm/page_alloc.c
index 2f644c3..ce2a026 100644
--- a/mm/page_alloc.c
+++ b/mm/page_alloc.c
@@ -3381,10 +3381,8 @@ static void __init setup_usemap(struct pglist_data *pgdat,
unsigned long usemapsize = usemap_size(zonesize);
zone->pageblock_flags = NULL;
- if (usemapsize) {
+ if (usemapsize)
zone->pageblock_flags = alloc_bootmem_node(pgdat, usemapsize);
- memset(zone->pageblock_flags, 0, usemapsize);
#else
static void inline setup_usemap(struct pglist_data *pgdat, |
- if (usemapsize) {
+ if (usemapsize)
#else
