usb: musb: davinci: use devm_ functions.
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, a label is done away with and clk_get is replaced by it
corresponding devm version and the clk_puts are done away with. The
labels are renamed to make them ordered.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Felipe Balbi
 drivers/usb/musb/davinci.c | 20 ++++++--------------
 1 file changed, 6 insertions(+), 14 deletions(-)
diff --git a/drivers/usb/musb/davinci.c b/drivers/usb/musb/davinci.c
index de8492b..110b784 100644
--- a/drivers/usb/musb/davinci.c
+++ b/drivers/usb/musb/davinci.c
@@ -519,23 +519,23 @@ static int davinci_probe(struct platform_device *pdev)
 	int				ret = -ENOMEM;
-	glue = kzalloc(sizeof(*glue), GFP_KERNEL);
+	glue = devm_kzalloc(&pdev->dev, sizeof(*glue), GFP_KERNEL);
 	if (!glue) {
 		dev_err(&pdev->dev, "failed to allocate glue context\n");
 		goto err0;
-	clk = clk_get(&pdev->dev, "usb");
+	clk = devm_clk_get(&pdev->dev, "usb");
 	if (IS_ERR(clk)) {
 		dev_err(&pdev->dev, "failed to get clock\n");
 		ret = PTR_ERR(clk);
-		goto err3;
+		goto err0;
 	ret = clk_enable(clk);
 	if (ret) {
 		dev_err(&pdev->dev, "failed to enable clock\n");
-		goto err4;
+		goto err0;
 	glue->dev			= &pdev->dev;
@@ -579,20 +579,14 @@ static int davinci_probe(struct platform_device *pdev)
 	if (IS_ERR(musb)) {
 		ret = PTR_ERR(musb);
 		dev_err(&pdev->dev, "failed to register musb device: %d\n", ret);
-		goto err5;
+		goto err1;
 	return 0;
-err5:
+err1:
 	clk_disable(clk);
-err4:
-	clk_put(clk);
-err3:
-	kfree(glue);
 err0:
 	return ret;
@@ -604,8 +598,6 @@ static int davinci_remove(struct platform_device *pdev)
 	platform_device_unregister(glue->musb);
 	usb_phy_generic_unregister();
 	clk_disable(glue->clk);
-	clk_put(glue->clk);
-	kfree(glue);
 	return 0;
BtrLinux
Privacy Overview
