lpc_eth: Use resource_size instead of computation
Author: Benoit Taine <benoit.taine@lip6.fr>
This issue was reported by coccicheck using the semantic patch
at scripts/coccinelle/api/resource_size.cocci
Signed-off-by: Benoit Taine
Signed-off-by: David S. Miller
drivers/net/ethernet/nxp/lpc_eth.c | 8 +++-----
1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ethernet/nxp/lpc_eth.c b/drivers/net/ethernet/nxp/lpc_eth.c
index 422d9b5..8706c0d 100644
--- a/drivers/net/ethernet/nxp/lpc_eth.c
+++ b/drivers/net/ethernet/nxp/lpc_eth.c
@@ -1361,7 +1361,7 @@ static int lpc_eth_drv_probe(struct platform_device *pdev)
__lpc_eth_clock_enable(pldat, true);
/* Map IO space */
- pldat->net_base = ioremap(res->start, res->end - res->start + 1);
+ pldat->net_base = ioremap(res->start, resource_size(res));
if (!pldat->net_base) {
dev_err(&pdev->dev, "failed to map registers\n");
ret = -ENOMEM;
@@ -1417,10 +1417,8 @@ static int lpc_eth_drv_probe(struct platform_device *pdev)
pldat->dma_buff_base_p = dma_handle;
- netdev_dbg(ndev, "IO address start :0x%08x\n",
- res->start);
- netdev_dbg(ndev, "IO address size :%d\n",
- res->end - res->start + 1);
+ netdev_dbg(ndev, "IO address space :%pR\n", res);
+ netdev_dbg(ndev, "IO address size :%d\n", resource_size(res));
netdev_dbg(ndev, "IO address (mapped) :0x%p\n",
pldat->net_base);
netdev_dbg(ndev, "IRQ number :%d\n", ndev->irq); |
/* Map IO space */
ret = -ENOMEM;
- res->start);
pldat->net_base);
