usb: isp1760: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
Signed-off-by: Julia Lawall
 drivers/usb/host/isp1760-hcd.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/usb/host/isp1760-hcd.c b/drivers/usb/host/isp1760-hcd.c
index 395649f..79261d5 100644
--- a/drivers/usb/host/isp1760-hcd.c
+++ b/drivers/usb/host/isp1760-hcd.c
@@ -1359,9 +1359,7 @@ static int isp1760_run(struct usb_hcd *hcd)
 	if (retval)
 		return retval;
-	init_timer(&errata2_timer);
-	errata2_timer.function = errata2_function;
-	errata2_timer.data = (unsigned long) hcd;
+	setup_timer(&errata2_timer, errata2_function, (unsigned long)hcd);
 	errata2_timer.expires = jiffies + SLOT_CHECK_PERIOD * HZ / 1000;
 	add_timer(&errata2_timer);
BtrLinux
Privacy Overview
