[media] pvrusb2: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
Signed-off-by: Julia Lawall
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
drivers/media/usb/pvrusb2/pvrusb2-hdw.c | 26 ++++++++++----------------
1 file changed, 10 insertions(+), 16 deletions(-)
diff --git a/drivers/media/usb/pvrusb2/pvrusb2-hdw.c b/drivers/media/usb/pvrusb2/pvrusb2-hdw.c
index 2fd9b5e..08f2f5a 100644
--- a/drivers/media/usb/pvrusb2/pvrusb2-hdw.c
+++ b/drivers/media/usb/pvrusb2/pvrusb2-hdw.c
@@ -2425,22 +2425,18 @@ struct pvr2_hdw *pvr2_hdw_create(struct usb_interface *intf,
if (!hdw) goto fail;
- init_timer(&hdw->quiescent_timer);
- hdw->quiescent_timer.data = (unsigned long)hdw;
- hdw->quiescent_timer.function = pvr2_hdw_quiescent_timeout;
+ setup_timer(&hdw->quiescent_timer, pvr2_hdw_quiescent_timeout,
+ (unsigned long)hdw);
- init_timer(&hdw->decoder_stabilization_timer);
- hdw->decoder_stabilization_timer.data = (unsigned long)hdw;
- hdw->decoder_stabilization_timer.function =
- pvr2_hdw_decoder_stabilization_timeout;
+ setup_timer(&hdw->decoder_stabilization_timer,
+ pvr2_hdw_decoder_stabilization_timeout,
- init_timer(&hdw->encoder_wait_timer);
- hdw->encoder_wait_timer.data = (unsigned long)hdw;
- hdw->encoder_wait_timer.function = pvr2_hdw_encoder_wait_timeout;
+ setup_timer(&hdw->encoder_wait_timer, pvr2_hdw_encoder_wait_timeout,
- init_timer(&hdw->encoder_run_timer);
- hdw->encoder_run_timer.data = (unsigned long)hdw;
- hdw->encoder_run_timer.function = pvr2_hdw_encoder_run_timeout;
+ setup_timer(&hdw->encoder_run_timer, pvr2_hdw_encoder_run_timeout,
hdw->master_state = PVR2_STATE_DEAD;
@@ -3680,10 +3676,8 @@ static int pvr2_send_request_ex(struct pvr2_hdw *hdw,
hdw->ctl_timeout_flag = 0;
hdw->ctl_write_pend_flag = 0;
hdw->ctl_read_pend_flag = 0;
- init_timer(&timer);
+ setup_timer(&timer, pvr2_ctl_timeout, (unsigned long)hdw);
timer.expires = jiffies + timeout;
- timer.data = (unsigned long)hdw;
- timer.function = pvr2_ctl_timeout;
if (write_len) {
hdw->cmd_debug_state = 2; |
if (write_len) {
