USB: isp116x-hcd.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Olav Kongas
Reviewed-by: Felipe Balbi
drivers/usb/host/isp116x-hcd.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/isp116x-hcd.c b/drivers/usb/host/isp116x-hcd.c
index 13181dc..d089b3f 100644
--- a/drivers/usb/host/isp116x-hcd.c
+++ b/drivers/usb/host/isp116x-hcd.c
@@ -500,7 +500,8 @@ static void start_atl_transfers(struct isp116x *isp116x)
if (isp116x->periodic_count) {
isp116x->fmindex = index =
(isp116x->fmindex + 1) & (PERIODIC_SIZE - 1);
- if ((load = isp116x->load[index])) {
+ load = isp116x->load[index];
+ if (load) {
/* Bring all int transfers for this frame
into the active queue */
isp116x->atl_active = last_ep = |
+ if (load) {
