USB: mon_bin.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Reviewed-by: Felipe Balbi
 drivers/usb/mon/mon_bin.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/mon/mon_bin.c b/drivers/usb/mon/mon_bin.c
index 9a62e89..3598f1a 100644
--- a/drivers/usb/mon/mon_bin.c
+++ b/drivers/usb/mon/mon_bin.c
@@ -675,7 +675,8 @@ static int mon_bin_open(struct inode *inode, struct file *file)
 	int rc;
 	mutex_lock(&mon_lock);
-	if ((mbus = mon_bus_lookup(iminor(inode))) == NULL) {
+	mbus = mon_bus_lookup(iminor(inode));
+	if (mbus == NULL) {
 		mutex_unlock(&mon_lock);
 		return -ENODEV;
@@ -1018,8 +1019,8 @@ static long mon_bin_ioctl(struct file *file, unsigned int cmd, unsigned long arg
 			return -EINVAL;
 		size = CHUNK_ALIGN(arg);
-		if ((vec = kzalloc(sizeof(struct mon_pgmap) * (size/CHUNK_SIZE),
-		    GFP_KERNEL)) == NULL) {
+		vec = kzalloc(sizeof(struct mon_pgmap) * (size / CHUNK_SIZE), GFP_KERNEL);
+		if (vec == NULL) {
 			ret = -ENOMEM;
 			break;
