USB: ehci-omap.c: introduce missing kfree
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
drivers/usb/host/ehci-omap.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-omap.c b/drivers/usb/host/ehci-omap.c
index 7ba8df3..12f1ad2 100644
--- a/drivers/usb/host/ehci-omap.c
+++ b/drivers/usb/host/ehci-omap.c
@@ -558,7 +558,7 @@ static int ehci_hcd_omap_probe(struct platform_device *pdev)
omap = kzalloc(sizeof(*omap), GFP_KERNEL);
if (!omap) {
ret = -ENOMEM;
- goto err_create_hcd;
+ goto err_disabled;
hcd = usb_create_hcd(&ehci_omap_hc_driver, &pdev->dev,
@@ -653,6 +653,7 @@ err_ioremap:
usb_put_hcd(hcd);
err_create_hcd:
+ kfree(omap);
err_disabled:
err_pdata:
return ret; |
if (!omap) {
ret = -ENOMEM;
usb_put_hcd(hcd);
err_create_hcd:
+ kfree(omap);
err_disabled:
err_pdata:
return ret;
