fs/ceph: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Sage Weil
fs/ceph/xattr.c | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/fs/ceph/xattr.c b/fs/ceph/xattr.c
index 1a48a55..04769a3 100644
--- a/fs/ceph/xattr.c
+++ b/fs/ceph/xattr.c
@@ -655,8 +655,10 @@ static int ceph_sync_setxattr(struct dentry *dentry, const char *name,
/* do request */
req = ceph_mdsc_create_request(mdsc, CEPH_MDS_OP_SETXATTR,
USE_AUTH_MDS);
- if (IS_ERR(req))
- return PTR_ERR(req);
+ if (IS_ERR(req)) {
+ err = PTR_ERR(req);
+ goto out;
req->r_inode = igrab(inode);
req->r_inode_drop = CEPH_CAP_XATTR_SHARED;
req->r_num_caps = 1; |
/* do request */
USE_AUTH_MDS);
- if (IS_ERR(req))
+ goto out;
