usb: chipidea: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/usb/chipidea/ci_hdrc_usb2.c:108:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Cc: Antoine Tenart
Cc: Peter Chen
Signed-off-by: Fengguang Wu
 drivers/usb/chipidea/ci_hdrc_usb2.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/usb/chipidea/ci_hdrc_usb2.c b/drivers/usb/chipidea/ci_hdrc_usb2.c
index 61d8e55..45844c9 100644
--- a/drivers/usb/chipidea/ci_hdrc_usb2.c
+++ b/drivers/usb/chipidea/ci_hdrc_usb2.c
@@ -105,7 +105,6 @@ static struct platform_driver ci_hdrc_usb2_driver = {
 	.remove	= ci_hdrc_usb2_remove,
 	.driver	= {
 		.name		= "chipidea-usb2",
-		.owner		= THIS_MODULE,
 		.of_match_table	= of_match_ptr(ci_hdrc_usb2_of_match),
BtrLinux
Privacy Overview
