arch/arm/mach-at91/Makefile | 1 -
arch/arm/mach-at91/at91_aic.h | 99 ------------
arch/arm/mach-at91/board-dt-rm9200.c | 1 -
arch/arm/mach-at91/board-dt-sam9.c | 1 -
arch/arm/mach-at91/board-dt-sama5.c | 1 -
arch/arm/mach-at91/generic.h | 2 -
arch/arm/mach-at91/irq.c | 296 -----------------------------------
arch/arm/mach-at91/pm.c | 22 ---
arch/arm/mach-at91/setup.c | 4 -
9 files changed, 427 deletions(-)
diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile
index b486c77..2371b88 100644
--- a/arch/arm/mach-at91/Makefile
+++ b/arch/arm/mach-at91/Makefile
@@ -4,7 +4,6 @@
obj-y := gpio.o setup.o sysirq_mask.o
-obj-$(CONFIG_OLD_IRQ_AT91) += irq.o
obj-$(CONFIG_SOC_AT91SAM9) += sam9_smc.o
# CPU-specific support
diff --git a/arch/arm/mach-at91/at91_aic.h b/arch/arm/mach-at91/at91_aic.h
deleted file mode 100644
index eaea661..0000000
--- a/arch/arm/mach-at91/at91_aic.h
+++ /dev/null
@@ -1,99 +0,0 @@
- * arch/arm/mach-at91/include/mach/at91_aic.h
- * Copyright (C) 2005 Ivan Kokshaysky
- * Copyright (C) SAN People
- * Advanced Interrupt Controller (AIC) - System peripherals registers.
- * Based on AT91RM9200 datasheet revision E.
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
-#ifndef AT91_AIC_H
-#define AT91_AIC_H
-#ifndef __ASSEMBLY__
-extern void __iomem *at91_aic_base;
-#define at91_aic_read(field) \
- __raw_readl(at91_aic_base + field)
-#define at91_aic_write(field, value) \
- __raw_writel(value, at91_aic_base + field)
-#else
-.extern at91_aic_base
-#endif
-/* Number of irq lines managed by AIC */
-#define NR_AIC_IRQS 32
-#define NR_AIC5_IRQS 128
-#define AT91_AIC5_SSR 0x0 /* Source Select Register [AIC5] */
-#define AT91_AIC5_INTSEL_MSK (0x7f << 0) /* Interrupt Line Selection Mask */
-#define AT91_AIC_IRQ_MIN_PRIORITY 0
-#define AT91_AIC_IRQ_MAX_PRIORITY 7
-#define AT91_AIC_SMR(n) ((n) * 4) /* Source Mode Registers 0-31 */
-#define AT91_AIC5_SMR 0x4 /* Source Mode Register [AIC5] */
-#define AT91_AIC_PRIOR (7 << 0) /* Priority Level */
-#define AT91_AIC_SRCTYPE (3 << 5) /* Interrupt Source Type */
-#define AT91_AIC_SRCTYPE_LOW (0 << 5)
-#define AT91_AIC_SRCTYPE_FALLING (1 << 5)
-#define AT91_AIC_SRCTYPE_HIGH (2 << 5)
-#define AT91_AIC_SRCTYPE_RISING (3 << 5)
-#define AT91_AIC_SVR(n) (0x80 + ((n) * 4)) /* Source Vector Registers 0-31 */
-#define AT91_AIC5_SVR 0x8 /* Source Vector Register [AIC5] */
-#define AT91_AIC_IVR 0x100 /* Interrupt Vector Register */
-#define AT91_AIC5_IVR 0x10 /* Interrupt Vector Register [AIC5] */
-#define AT91_AIC_FVR 0x104 /* Fast Interrupt Vector Register */
-#define AT91_AIC5_FVR 0x14 /* Fast Interrupt Vector Register [AIC5] */
-#define AT91_AIC_ISR 0x108 /* Interrupt Status Register */
-#define AT91_AIC5_ISR 0x18 /* Interrupt Status Register [AIC5] */
-#define AT91_AIC_IRQID (0x1f << 0) /* Current Interrupt Identifier */
-#define AT91_AIC_IPR 0x10c /* Interrupt Pending Register */
-#define AT91_AIC5_IPR0 0x20 /* Interrupt Pending Register 0 [AIC5] */
-#define AT91_AIC5_IPR1 0x24 /* Interrupt Pending Register 1 [AIC5] */
-#define AT91_AIC5_IPR2 0x28 /* Interrupt Pending Register 2 [AIC5] */
-#define AT91_AIC5_IPR3 0x2c /* Interrupt Pending Register 3 [AIC5] */
-#define AT91_AIC_IMR 0x110 /* Interrupt Mask Register */
-#define AT91_AIC5_IMR 0x30 /* Interrupt Mask Register [AIC5] */
-#define AT91_AIC_CISR 0x114 /* Core Interrupt Status Register */
-#define AT91_AIC5_CISR 0x34 /* Core Interrupt Status Register [AIC5] */
-#define AT91_AIC_NFIQ (1 << 0) /* nFIQ Status */
-#define AT91_AIC_NIRQ (1 << 1) /* nIRQ Status */
-#define AT91_AIC_IECR 0x120 /* Interrupt Enable Command Register */
-#define AT91_AIC5_IECR 0x40 /* Interrupt Enable Command Register [AIC5] */
-#define AT91_AIC_IDCR 0x124 /* Interrupt Disable Command Register */
-#define AT91_AIC5_IDCR 0x44 /* Interrupt Disable Command Register [AIC5] */
-#define AT91_AIC_ICCR 0x128 /* Interrupt Clear Command Register */
-#define AT91_AIC5_ICCR 0x48 /* Interrupt Clear Command Register [AIC5] */
-#define AT91_AIC_ISCR 0x12c /* Interrupt Set Command Register */
-#define AT91_AIC5_ISCR 0x4c /* Interrupt Set Command Register [AIC5] */
-#define AT91_AIC_EOICR 0x130 /* End of Interrupt Command Register */
-#define AT91_AIC5_EOICR 0x38 /* End of Interrupt Command Register [AIC5] */
-#define AT91_AIC_SPU 0x134 /* Spurious Interrupt Vector Register */
-#define AT91_AIC5_SPU 0x3c /* Spurious Interrupt Vector Register [AIC5] */
-#define AT91_AIC_DCR 0x138 /* Debug Control Register */
-#define AT91_AIC5_DCR 0x6c /* Debug Control Register [AIC5] */
-#define AT91_AIC_DCR_PROT (1 << 0) /* Protection Mode */
-#define AT91_AIC_DCR_GMSK (1 << 1) /* General Mask */
-#define AT91_AIC_FFER 0x140 /* Fast Forcing Enable Register [SAM9 only] */
-#define AT91_AIC5_FFER 0x50 /* Fast Forcing Enable Register [AIC5] */
-#define AT91_AIC_FFDR 0x144 /* Fast Forcing Disable Register [SAM9 only] */
-#define AT91_AIC5_FFDR 0x54 /* Fast Forcing Disable Register [AIC5] */
-#define AT91_AIC_FFSR 0x148 /* Fast Forcing Status Register [SAM9 only] */
-#define AT91_AIC5_FFSR 0x58 /* Fast Forcing Status Register [AIC5] */
-void at91_aic_handle_irq(struct pt_regs *regs);
-void at91_aic5_handle_irq(struct pt_regs *regs);
-#endif
diff --git a/arch/arm/mach-at91/board-dt-rm9200.c b/arch/arm/mach-at91/board-dt-rm9200.c
index 226563f..feeb1a0 100644
--- a/arch/arm/mach-at91/board-dt-rm9200.c
+++ b/arch/arm/mach-at91/board-dt-rm9200.c
@@ -22,7 +22,6 @@
#include <asm/mach/map.h>
#include <asm/mach/irq.h>
-#include "at91_aic.h"
#include "generic.h"
static void __init at91rm9200_dt_timer_init(void)
diff --git a/arch/arm/mach-at91/board-dt-sam9.c b/arch/arm/mach-at91/board-dt-sam9.c
index d3048cc..67c1bcb 100644
--- a/arch/arm/mach-at91/board-dt-sam9.c
+++ b/arch/arm/mach-at91/board-dt-sam9.c
@@ -21,7 +21,6 @@
#include "board.h"
diff --git a/arch/arm/mach-at91/board-dt-sama5.c b/arch/arm/mach-at91/board-dt-sama5.c
index 129e291..8fb9ef5 100644
--- a/arch/arm/mach-at91/board-dt-sama5.c
+++ b/arch/arm/mach-at91/board-dt-sama5.c
@@ -24,7 +24,6 @@
static void __init sama5_dt_device_init(void)
diff --git a/arch/arm/mach-at91/generic.h b/arch/arm/mach-at91/generic.h
index 1ec9b01..713d1d9 100644
--- a/arch/arm/mach-at91/generic.h
+++ b/arch/arm/mach-at91/generic.h
@@ -29,8 +29,6 @@ extern void __init at91_dt_initialize(void);
/* Interrupts */
extern void __init at91_init_irq_default(void);
extern void __init at91_init_interrupts(unsigned int priority[]);
-extern void __init at91_aic_init(unsigned int priority[],
- unsigned int ext_irq_mask);
extern int __init at91_aic_of_init(struct device_node *node,
struct device_node *parent);
extern int __init at91_aic5_of_init(struct device_node *node,
diff --git a/arch/arm/mach-at91/irq.c b/arch/arm/mach-at91/irq.c
index cdb3ec9..0000000
--- a/arch/arm/mach-at91/irq.c
+++ /dev/null
@@ -1,296 +0,0 @@
- * linux/arch/arm/mach-at91/irq.c
- * Copyright (C) 2004 SAN People
- * Copyright (C) 2004 ATMEL
- * Copyright (C) Rick Bronson
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
-#include <linux/init.h>
-#include <linux/module.h>
-#include <linux/mm.h>
-#include <linux/bitmap.h>
-#include <linux/types.h>
-#include <linux/irq.h>
-#include <linux/of.h>
-#include <linux/of_address.h>
-#include <linux/of_irq.h>
-#include <linux/irqdomain.h>
-#include <linux/err.h>
-#include <linux/slab.h>
-#include <mach/hardware.h>
-#include <asm/irq.h>
-#include <asm/setup.h>
-#include <asm/exception.h>
-#include <asm/mach/arch.h>
-#include <asm/mach/irq.h>
-#include <asm/mach/map.h>
-void __iomem *at91_aic_base;
-static struct irq_domain *at91_aic_domain;
-static struct device_node *at91_aic_np;
-static unsigned int n_irqs = NR_AIC_IRQS;
-#ifdef CONFIG_PM
-static unsigned long *wakeups;
-static unsigned long *backups;
-#define set_backup(bit) set_bit(bit, backups)
-#define clear_backup(bit) clear_bit(bit, backups)
-static int at91_aic_pm_init(void)
- backups = kzalloc(BITS_TO_LONGS(n_irqs) * sizeof(*backups), GFP_KERNEL);
- if (!backups)
- return -ENOMEM;
- wakeups = kzalloc(BITS_TO_LONGS(n_irqs) * sizeof(*backups), GFP_KERNEL);
- if (!wakeups) {
- kfree(backups);
- return -ENOMEM;
- return 0;
-static int at91_aic_set_wake(struct irq_data *d, unsigned value)
- if (unlikely(d->hwirq >= n_irqs))
- return -EINVAL;
- if (value)
- set_bit(d->hwirq, wakeups);
- else
- clear_bit(d->hwirq, wakeups);
- return 0;
-void at91_irq_suspend(void)
- at91_aic_write(AT91_AIC_IDCR, *backups);
- at91_aic_write(AT91_AIC_IECR, *wakeups);
-void at91_irq_resume(void)
- at91_aic_write(AT91_AIC_IDCR, *wakeups);
- at91_aic_write(AT91_AIC_IECR, *backups);
-#else
-static inline int at91_aic_pm_init(void)
- return 0;
-#define at91_aic_set_wake NULL
-#endif /* CONFIG_PM */
-asmlinkage void __exception_irq_entry
-at91_aic_handle_irq(struct pt_regs *regs)
- u32 irqnr;
- u32 irqstat;
- irqnr = at91_aic_read(AT91_AIC_IVR);
- irqstat = at91_aic_read(AT91_AIC_ISR);
- * ISR value is 0 when there is no current interrupt or when there is
- * a spurious interrupt
- if (!irqstat)
- at91_aic_write(AT91_AIC_EOICR, 0);
- else
- handle_IRQ(irqnr, regs);
-static void at91_aic_mask_irq(struct irq_data *d)
- /* Disable interrupt on AIC */
- at91_aic_write(AT91_AIC_IDCR, 1 << d->hwirq);
- /* Update ISR cache */
- clear_backup(d->hwirq);
-static void at91_aic_unmask_irq(struct irq_data *d)
- /* Enable interrupt on AIC */
- at91_aic_write(AT91_AIC_IECR, 1 << d->hwirq);
- set_backup(d->hwirq);
-static void at91_aic_eoi(struct irq_data *d)
- * Mark end-of-interrupt on AIC, the controller doesn't care about
- * the value written. Moreover it's a write-only register.
-static unsigned long *at91_extern_irq;
-u32 at91_get_extern_irq(void)
- if (!at91_extern_irq)
- return 0;
- return *at91_extern_irq;
-#define is_extern_irq(hwirq) test_bit(hwirq, at91_extern_irq)
-static int at91_aic_compute_srctype(struct irq_data *d, unsigned type)
- int srctype;
- switch (type) {
- case IRQ_TYPE_LEVEL_HIGH:
- srctype = AT91_AIC_SRCTYPE_HIGH;
- break;
- case IRQ_TYPE_EDGE_RISING:
- srctype = AT91_AIC_SRCTYPE_RISING;
- break;
- case IRQ_TYPE_LEVEL_LOW:
- if ((d->hwirq == AT91_ID_FIQ) || is_extern_irq(d->hwirq)) /* only supported on external interrupts */
- srctype = AT91_AIC_SRCTYPE_LOW;
- else
- srctype = -EINVAL;
- break;
- case IRQ_TYPE_EDGE_FALLING:
- srctype = AT91_AIC_SRCTYPE_FALLING;
- else
- break;
- default:
- return srctype;
-static int at91_aic_set_type(struct irq_data *d, unsigned type)
- unsigned int smr;
- int srctype;
- srctype = at91_aic_compute_srctype(d, type);
- if (srctype < 0)
- return srctype;
- smr = at91_aic_read(AT91_AIC_SMR(d->hwirq)) & ~AT91_AIC_SRCTYPE;
- at91_aic_write(AT91_AIC_SMR(d->hwirq), smr | srctype);
- return 0;
-static struct irq_chip at91_aic_chip = {
- .name = "AIC",
- .irq_mask = at91_aic_mask_irq,
- .irq_unmask = at91_aic_unmask_irq,
- .irq_set_type = at91_aic_set_type,
- .irq_set_wake = at91_aic_set_wake,
- .irq_eoi = at91_aic_eoi,
-static void __init at91_aic_hw_init(unsigned int spu_vector)
- int i;
- * Perform 8 End Of Interrupt Command to make sure AIC
- * will not Lock out nIRQ
- for (i = 0; i < 8; i++)
- * Spurious Interrupt ID in Spurious Vector Register.
- * When there is no current interrupt, the IRQ Vector Register
- * reads the value stored in AIC_SPU
- at91_aic_write(AT91_AIC_SPU, spu_vector);
- /* No debugging in AIC: Debug (Protect) Control Register */
- at91_aic_write(AT91_AIC_DCR, 0);
- /* Disable and clear all interrupts initially */
- at91_aic_write(AT91_AIC_IDCR, 0xFFFFFFFF);
- at91_aic_write(AT91_AIC_ICCR, 0xFFFFFFFF);
- * Initialize the AIC interrupt controller.
-void __init at91_aic_init(unsigned int *priority, unsigned int ext_irq_mask)
- unsigned int i;
- int irq_base;
- at91_extern_irq = kzalloc(BITS_TO_LONGS(n_irqs)
- * sizeof(*at91_extern_irq), GFP_KERNEL);
- if (at91_aic_pm_init() || at91_extern_irq == NULL)
- panic("Unable to allocate bit maps\n");
- *at91_extern_irq = ext_irq_mask;
- at91_aic_base = ioremap(AT91_AIC, 512);
- if (!at91_aic_base)
- panic("Unable to ioremap AIC registers\n");
- /* Add irq domain for AIC */
- irq_base = irq_alloc_descs(-1, 0, n_irqs, 0);
- if (irq_base < 0) {
- WARN(1, "Cannot allocate irq_descs, assuming pre-allocated\n");
- irq_base = 0;
- at91_aic_domain = irq_domain_add_legacy(at91_aic_np, n_irqs,
- irq_base, 0,
- &irq_domain_simple_ops, NULL);
- if (!at91_aic_domain)
- panic("Unable to add AIC irq domain\n");
- irq_set_default_host(at91_aic_domain);
- * The IVR is used by macro get_irqnr_and_base to read and verify.
- * The irq number is NR_AIC_IRQS when a spurious interrupt has occurred.
- for (i = 0; i < n_irqs; i++) {
- /* Put hardware irq number in Source Vector Register: */
- at91_aic_write(AT91_AIC_SVR(i), NR_IRQS_LEGACY + i);
- /* Active Low interrupt, with the specified priority */
- at91_aic_write(AT91_AIC_SMR(i), AT91_AIC_SRCTYPE_LOW | priority[i]);
- irq_set_chip_and_handler(NR_IRQS_LEGACY + i, &at91_aic_chip, handle_fasteoi_irq);
- set_irq_flags(i, IRQF_VALID | IRQF_PROBE);
- at91_aic_hw_init(n_irqs);
diff --git a/arch/arm/mach-at91/pm.c b/arch/arm/mach-at91/pm.c
index 4073ab7..a42360f 100644
--- a/arch/arm/mach-at91/pm.c
+++ b/arch/arm/mach-at91/pm.c
@@ -29,7 +29,6 @@
#include <mach/cpu.h>
#include "pm.h"
#include "gpio.h"
@@ -136,19 +135,6 @@ static int at91_pm_enter(suspend_state_t state)
else
at91_gpio_suspend();
- if (IS_ENABLED(CONFIG_OLD_IRQ_AT91) && at91_aic_base) {
- at91_irq_suspend();
- pr_debug("AT91: PM - wake mask %08x, pm state %d\n",
- /* remember all the always-wake irqs */
- (at91_pmc_read(AT91_PMC_PCSR)
- | (1 << AT91_ID_FIQ)
- | (1 << AT91_ID_SYS)
- | (at91_get_extern_irq()))
- & at91_aic_read(AT91_AIC_IMR),
- state);
switch (state) {
* Suspend-to-RAM is like STANDBY plus slow clock mode, so
@@ -212,17 +198,9 @@ static int at91_pm_enter(suspend_state_t state)
goto error;
- pr_debug("AT91: PM - wakeup %08x\n",
- at91_aic_read(AT91_AIC_IPR) &
- at91_aic_read(AT91_AIC_IMR));
error:
target_state = PM_SUSPEND_ON;
- at91_irq_resume();
if (of_have_populated_dt())
at91_pinctrl_gpio_resume();
else
diff --git a/arch/arm/mach-at91/setup.c b/arch/arm/mach-at91/setup.c
index 98b0c1a..6c3013e 100644
--- a/arch/arm/mach-at91/setup.c
+++ b/arch/arm/mach-at91/setup.c
@@ -49,10 +49,6 @@ void __init at91_init_irq_default(void)
void __init at91_init_interrupts(unsigned int *priority)
- /* Initialize the AIC interrupt controller */
- if (IS_ENABLED(CONFIG_OLD_IRQ_AT91))
- at91_aic_init(priority, at91_boot_soc.extern_irq);
/* Enable GPIO interrupts */
at91_gpio_irq_setup();
