tty: ar933x_uart: simplify use of devm_ioremap_resource
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  ... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
  ... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
  e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
 drivers/tty/serial/ar933x_uart.c | 7 +------
 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/tty/serial/ar933x_uart.c b/drivers/tty/serial/ar933x_uart.c
index 3f5517f..a712a3f 100644
--- a/drivers/tty/serial/ar933x_uart.c
+++ b/drivers/tty/serial/ar933x_uart.c
@@ -640,12 +640,6 @@ static int ar933x_uart_probe(struct platform_device *pdev)
 	if (id > CONFIG_SERIAL_AR933X_NR_UARTS)
 		return -EINVAL;
-	mem_res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!mem_res) {
-		dev_err(&pdev->dev, "no MEM resource\n");
-		return -EINVAL;
 	irq_res = platform_get_resource(pdev, IORESOURCE_IRQ, 0);
 	if (!irq_res) {
 		dev_err(&pdev->dev, "no IRQ resource\n");
@@ -659,6 +653,7 @@ static int ar933x_uart_probe(struct platform_device *pdev)
 	port = &up->port;
+	mem_res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	port->membase = devm_ioremap_resource(&pdev->dev, mem_res);
 	if (IS_ERR(port->membase))
 		return PTR_ERR(port->membase);
BtrLinux
Privacy Overview
