[TIPC]: Use tipc_port_unlock
The file net/tipc/port.c takes a lock using the function tipc_port_lock and
then releases the lock sometimes using tipc_port_unlock and sometimes using
spin_unlock_bh(p_ptr->publ.lock).  tipc_port_unlock simply does the
spin_unlock_bh, but it seems cleaner to use it everywhere.
The problem was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
struct port *p_ptr;
   p_ptr = tipc_port_lock(...)
   p_ptr = tipc_port_lock(...);
?- spin_unlock_bh(p_ptr->publ.lock);
+  tipc_port_unlock(p_ptr);
Signed-off-by: Julia Lawall
Acked-by: Jon Paul Maloy
Signed-off-by: David S. Miller
 net/tipc/port.c | 20 ++++++++++----------
 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/net/tipc/port.c b/net/tipc/port.c
index 7608815..f508614 100644
--- a/net/tipc/port.c
+++ b/net/tipc/port.c
@@ -340,7 +340,7 @@ int tipc_portunreliable(u32 ref, unsigned int *isunreliable)
 	if (!p_ptr)
 		return -EINVAL;
 	*isunreliable = port_unreliable(p_ptr);
 	return TIPC_OK;
@@ -369,7 +369,7 @@ int tipc_portunreturnable(u32 ref, unsigned int *isunrejectable)
 	if (!p_ptr)
 		return -EINVAL;
 	*isunrejectable = port_unreturnable(p_ptr);
 	return TIPC_OK;
@@ -843,7 +843,7 @@ static void port_dispatcher_sigh(void *dummy)
 				u32 peer_port = port_peerport(p_ptr);
 				u32 peer_node = port_peernode(p_ptr);
 				if (unlikely(!connected)) {
 					if (unlikely(published))
 						goto reject;
@@ -867,7 +867,7 @@ static void port_dispatcher_sigh(void *dummy)
 		case TIPC_DIRECT_MSG:{
 				tipc_msg_event cb = up_ptr->msg_cb;
 				if (unlikely(connected))
 					goto reject;
 				if (unlikely(!cb))
@@ -882,7 +882,7 @@ static void port_dispatcher_sigh(void *dummy)
 		case TIPC_NAMED_MSG:{
 				tipc_named_msg_event cb = up_ptr->named_msg_cb;
 					goto reject;
 				if (unlikely(!cb))
@@ -913,7 +913,7 @@ err:
 				if (!connected || !cb)
 					break;
 				if (msg_origport(msg) != peer_port)
@@ -929,7 +929,7 @@ err:
 				tipc_msg_err_event cb = up_ptr->err_cb;
 				if (connected || !cb)
 					break;
 				skb_pull(buf, msg_hdr_sz(msg));
@@ -942,7 +942,7 @@ err:
 				tipc_named_msg_err_event cb =
 					up_ptr->named_err_cb;
 					break;
 				dseq.type =  msg_nametype(msg);
@@ -1107,7 +1107,7 @@ int tipc_portimportance(u32 ref, unsigned int *importance)
 	if (!p_ptr)
 		return -EINVAL;
 	*importance = (unsigned int)msg_importance(&p_ptr->publ.phdr);
 	return TIPC_OK;
@@ -1122,7 +1122,7 @@ int tipc_set_portimportance(u32 ref, unsigned int imp)
 	if (!p_ptr)
 		return -EINVAL;
 	msg_set_importance(&p_ptr->publ.phdr, (u32)imp);
 	return TIPC_OK;
BtrLinux
Privacy Overview
