stmmac: fix ptr_ret.cocci warning
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c:304:1-3: WARNING: PTR_ERR_OR_ZERO can be used
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
Signed-off-by: Fengguang Wu
[je: rebase and insert newline before return]
Signed-off-by: Joachim Eastwood
Signed-off-by: David S. Miller
 drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c b/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
index eca0eb8..1dcb5eb 100644
--- a/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
+++ b/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
@@ -298,10 +298,8 @@ int stmmac_get_platform_resources(struct platform_device *pdev,
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	stmmac_res->addr = devm_ioremap_resource(&pdev->dev, res);
-	if (IS_ERR(stmmac_res->addr))
-		return PTR_ERR(stmmac_res->addr);
-	return 0;
+	return PTR_ERR_OR_ZERO(stmmac_res->addr);
 EXPORT_SYMBOL_GPL(stmmac_get_platform_resources);
BtrLinux
Privacy Overview
