Staging:dgap :Compression of lines for immediate return
Author: Shraddha Barke <shraddha.6596@gmail.com>
This patch compresses two lines into a single line
if immediate return statement is found. Remove variable rc as
it is no longer needed.
It is done using script Coccinelle. And coccinelle uses the following
semantic patch for this compression function:
type T;
identifier i,f;
constant C;
- T i;
...when != i
when strict
return -C;
- i =
+ return
f(...);
- return i;
Signed-off-by: Shraddha Barke
drivers/staging/dgap/dgap.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/dgap/dgap.c b/drivers/staging/dgap/dgap.c
index b344e03..9112dd2 100644
--- a/drivers/staging/dgap/dgap.c
+++ b/drivers/staging/dgap/dgap.c
@@ -4953,9 +4953,8 @@ static int dgap_tty_ioctl(struct tty_struct *tty, unsigned int cmd,
spin_unlock_irqrestore(&ch->ch_lock, lock_flags2);
spin_unlock_irqrestore(&bd->bd_lock, lock_flags);
- rc = put_user(C_CLOCAL(tty) ? 1 : 0,
+ return put_user(C_CLOCAL(tty) ? 1 : 0,
(unsigned long __user *) arg);
- return rc;
case TIOCSSOFTCAR:
spin_unlock_irqrestore(&ch->ch_lock, lock_flags2); |
- return rc;
case TIOCSSOFTCAR:
