drivers/staging/iio/accel/adis16201_core.c | 2 +-
drivers/staging/iio/accel/adis16203_core.c | 2 +-
drivers/staging/iio/accel/adis16204_core.c | 2 +-
drivers/staging/iio/accel/adis16209_core.c | 2 +-
drivers/staging/iio/accel/adis16240_core.c | 2 +-
drivers/staging/iio/accel/kxsd9.c | 2 +-
drivers/staging/iio/accel/lis3l02dq_core.c | 2 +-
drivers/staging/iio/accel/sca3000_core.c | 2 +-
drivers/staging/iio/adc/ad7192.c | 2 +-
drivers/staging/iio/adc/ad7298_core.c | 2 +-
drivers/staging/iio/adc/ad7606.h | 2 +-
drivers/staging/iio/adc/ad7606_core.c | 6 +++---
drivers/staging/iio/adc/lpc32xx_adc.c | 2 +-
drivers/staging/iio/adc/max1363.h | 2 +-
drivers/staging/iio/adc/max1363_core.c | 26 ++++++++++++-------------
drivers/staging/iio/adc/spear_adc.c | 2 +-
drivers/staging/iio/iio_simple_dummy.c | 2 +-
drivers/staging/iio/impedance-analyzer/ad5933.c | 2 +-
drivers/staging/iio/imu/adis16400_core.c | 6 +++---
drivers/staging/iio/meter/ade7758.h | 2 +-
drivers/staging/iio/meter/ade7758_core.c | 2 +-
drivers/staging/iio/resolver/ad2s1210.c | 2 +-
22 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/drivers/staging/iio/accel/adis16201_core.c b/drivers/staging/iio/accel/adis16201_core.c
index 204106b..ec2332f 100644
--- a/drivers/staging/iio/accel/adis16201_core.c
+++ b/drivers/staging/iio/accel/adis16201_core.c
@@ -390,7 +390,7 @@ static int adis16201_write_raw(struct iio_dev *indio_dev,
return -EINVAL;
-static struct iio_chan_spec adis16201_channels[] = {
+static const struct iio_chan_spec adis16201_channels[] = {
.type = IIO_VOLTAGE,
.indexed = 1,
diff --git a/drivers/staging/iio/accel/adis16203_core.c b/drivers/staging/iio/accel/adis16203_core.c
index 22085e9..34b76c5 100644
--- a/drivers/staging/iio/accel/adis16203_core.c
+++ b/drivers/staging/iio/accel/adis16203_core.c
@@ -355,7 +355,7 @@ static int adis16203_read_raw(struct iio_dev *indio_dev,
-static struct iio_chan_spec adis16203_channels[] = {
+static const struct iio_chan_spec adis16203_channels[] = {
.indexed = 1,
diff --git a/drivers/staging/iio/accel/adis16204_core.c b/drivers/staging/iio/accel/adis16204_core.c
index 5f2e5f1..02fb101 100644
--- a/drivers/staging/iio/accel/adis16204_core.c
+++ b/drivers/staging/iio/accel/adis16204_core.c
@@ -397,7 +397,7 @@ static int adis16204_write_raw(struct iio_dev *indio_dev,
return -EINVAL;
-static struct iio_chan_spec adis16204_channels[] = {
+static const struct iio_chan_spec adis16204_channels[] = {
.indexed = 1, /* Note was not previously indexed */
diff --git a/drivers/staging/iio/accel/adis16209_core.c b/drivers/staging/iio/accel/adis16209_core.c
index 4945705..4fa2229 100644
--- a/drivers/staging/iio/accel/adis16209_core.c
+++ b/drivers/staging/iio/accel/adis16209_core.c
@@ -390,7 +390,7 @@ static int adis16209_read_raw(struct iio_dev *indio_dev,
return -EINVAL;
-static struct iio_chan_spec adis16209_channels[] = {
+static const struct iio_chan_spec adis16209_channels[] = {
.indexed = 1,
diff --git a/drivers/staging/iio/accel/adis16240_core.c b/drivers/staging/iio/accel/adis16240_core.c
index b30b787..dafc0d8 100644
--- a/drivers/staging/iio/accel/adis16240_core.c
+++ b/drivers/staging/iio/accel/adis16240_core.c
@@ -448,7 +448,7 @@ static int adis16240_write_raw(struct iio_dev *indio_dev,
return -EINVAL;
-static struct iio_chan_spec adis16240_channels[] = {
+static const struct iio_chan_spec adis16240_channels[] = {
.indexed = 1,
diff --git a/drivers/staging/iio/accel/kxsd9.c b/drivers/staging/iio/accel/kxsd9.c
index 8cf7cd9..713469f 100644
--- a/drivers/staging/iio/accel/kxsd9.c
+++ b/drivers/staging/iio/accel/kxsd9.c
@@ -186,7 +186,7 @@ error_ret:
.address = KXSD9_REG_##axis, \
-static struct iio_chan_spec kxsd9_channels[] = {
+static const struct iio_chan_spec kxsd9_channels[] = {
KXSD9_ACCEL_CHAN(X), KXSD9_ACCEL_CHAN(Y), KXSD9_ACCEL_CHAN(Z),
diff --git a/drivers/staging/iio/accel/lis3l02dq_core.c b/drivers/staging/iio/accel/lis3l02dq_core.c
index 9d26348..0c2b4ba 100644
--- a/drivers/staging/iio/accel/lis3l02dq_core.c
+++ b/drivers/staging/iio/accel/lis3l02dq_core.c
@@ -538,7 +538,7 @@ static irqreturn_t lis3l02dq_event_handler(int irq, void *private)
.event_mask = LIS3L02DQ_EVENT_MASK, \
-static struct iio_chan_spec lis3l02dq_channels[] = {
+static const struct iio_chan_spec lis3l02dq_channels[] = {
LIS3L02DQ_CHAN(0, IIO_MOD_X),
LIS3L02DQ_CHAN(1, IIO_MOD_Y),
LIS3L02DQ_CHAN(2, IIO_MOD_Z),
diff --git a/drivers/staging/iio/accel/sca3000_core.c b/drivers/staging/iio/accel/sca3000_core.c
index c218d71..cc040e1 100644
--- a/drivers/staging/iio/accel/sca3000_core.c
+++ b/drivers/staging/iio/accel/sca3000_core.c
@@ -450,7 +450,7 @@ static IIO_DEVICE_ATTR(revision, S_IRUGO, sca3000_show_rev, NULL, 0);
.event_mask = SCA3000_EVENT_MASK, \
-static struct iio_chan_spec sca3000_channels[] = {
+static const struct iio_chan_spec sca3000_channels[] = {
SCA3000_CHAN(0, IIO_MOD_X),
SCA3000_CHAN(1, IIO_MOD_Y),
SCA3000_CHAN(2, IIO_MOD_Z),
diff --git a/drivers/staging/iio/adc/ad7192.c b/drivers/staging/iio/adc/ad7192.c
index 22c3923..e381d4b 100644
--- a/drivers/staging/iio/adc/ad7192.c
+++ b/drivers/staging/iio/adc/ad7192.c
@@ -967,7 +967,7 @@ static const struct iio_info ad7195_info = {
.scan_index = _si, \
.scan_type = IIO_ST('s', 24, 32, 0)}
-static struct iio_chan_spec ad7192_channels[] = {
+static const struct iio_chan_spec ad7192_channels[] = {
AD7192_CHAN_DIFF(1, 2, NULL, AD7192_CH_AIN1P_AIN2M, 0),
AD7192_CHAN_DIFF(3, 4, NULL, AD7192_CH_AIN3P_AIN4M, 1),
AD7192_CHAN_TEMP(0, AD7192_CH_TEMP, 2),
diff --git a/drivers/staging/iio/adc/ad7298_core.c b/drivers/staging/iio/adc/ad7298_core.c
index 6141f4a..4c75114 100644
--- a/drivers/staging/iio/adc/ad7298_core.c
+++ b/drivers/staging/iio/adc/ad7298_core.c
@@ -38,7 +38,7 @@
-static struct iio_chan_spec ad7298_channels[] = {
+static const struct iio_chan_spec ad7298_channels[] = {
.type = IIO_TEMP,
.indexed = 1,
diff --git a/drivers/staging/iio/adc/ad7606.h b/drivers/staging/iio/adc/ad7606.h
index 10f5989..9221a74 100644
--- a/drivers/staging/iio/adc/ad7606.h
+++ b/drivers/staging/iio/adc/ad7606.h
@@ -51,7 +51,7 @@ struct ad7606_platform_data {
struct ad7606_chip_info {
const char *name;
u16 int_vref_mv;
- struct iio_chan_spec *channels;
+ const struct iio_chan_spec *channels;
unsigned num_channels;
diff --git a/drivers/staging/iio/adc/ad7606_core.c b/drivers/staging/iio/adc/ad7606_core.c
index ccb97fe..bae61cb 100644
--- a/drivers/staging/iio/adc/ad7606_core.c
+++ b/drivers/staging/iio/adc/ad7606_core.c
@@ -241,7 +241,7 @@ static const struct attribute_group ad7606_attribute_group_range = {
.scan_type = IIO_ST('s', 16, 16, 0), \
-static struct iio_chan_spec ad7606_8_channels[] = {
+static const struct iio_chan_spec ad7606_8_channels[] = {
AD7606_CHANNEL(0),
AD7606_CHANNEL(1),
AD7606_CHANNEL(2),
@@ -253,7 +253,7 @@ static struct iio_chan_spec ad7606_8_channels[] = {
IIO_CHAN_SOFT_TIMESTAMP(8),
-static struct iio_chan_spec ad7606_6_channels[] = {
+static const struct iio_chan_spec ad7606_6_channels[] = {
AD7606_CHANNEL(0),
AD7606_CHANNEL(1),
AD7606_CHANNEL(2),
@@ -263,7 +263,7 @@ static struct iio_chan_spec ad7606_6_channels[] = {
IIO_CHAN_SOFT_TIMESTAMP(6),
-static struct iio_chan_spec ad7606_4_channels[] = {
+static const struct iio_chan_spec ad7606_4_channels[] = {
AD7606_CHANNEL(0),
AD7606_CHANNEL(1),
AD7606_CHANNEL(2),
diff --git a/drivers/staging/iio/adc/lpc32xx_adc.c b/drivers/staging/iio/adc/lpc32xx_adc.c
index 348d051..7e9bd00 100644
--- a/drivers/staging/iio/adc/lpc32xx_adc.c
+++ b/drivers/staging/iio/adc/lpc32xx_adc.c
@@ -108,7 +108,7 @@ static const struct iio_info lpc32xx_adc_iio_info = {
.scan_index = _index, \
-static struct iio_chan_spec lpc32xx_adc_iio_channels[] = {
+static const struct iio_chan_spec lpc32xx_adc_iio_channels[] = {
LPC32XX_ADC_CHANNEL(0),
LPC32XX_ADC_CHANNEL(1),
LPC32XX_ADC_CHANNEL(2),
diff --git a/drivers/staging/iio/adc/max1363.h b/drivers/staging/iio/adc/max1363.h
index 2cd0112..c746918 100644
--- a/drivers/staging/iio/adc/max1363.h
+++ b/drivers/staging/iio/adc/max1363.h
@@ -100,7 +100,7 @@ enum max1363_modes {
struct max1363_chip_info {
const struct iio_info *info;
int num_channels;
const enum max1363_modes *mode_list;
enum max1363_modes default_mode;
diff --git a/drivers/staging/iio/adc/max1363_core.c b/drivers/staging/iio/adc/max1363_core.c
index 6799ce2..816bb2c 100644
--- a/drivers/staging/iio/adc/max1363_core.c
+++ b/drivers/staging/iio/adc/max1363_core.c
@@ -335,12 +335,12 @@ static const enum max1363_modes max1363_mode_list[] = {
IIO_CHAN_SOFT_TIMESTAMP(8) \
-static struct iio_chan_spec max1036_channels[] = MAX1363_4X_CHANS(8, 0);
-static struct iio_chan_spec max1136_channels[] = MAX1363_4X_CHANS(10, 0);
-static struct iio_chan_spec max1236_channels[] = MAX1363_4X_CHANS(12, 0);
-static struct iio_chan_spec max1361_channels[] =
+static const struct iio_chan_spec max1036_channels[] = MAX1363_4X_CHANS(8, 0);
+static const struct iio_chan_spec max1136_channels[] = MAX1363_4X_CHANS(10, 0);
+static const struct iio_chan_spec max1236_channels[] = MAX1363_4X_CHANS(12, 0);
+static const struct iio_chan_spec max1361_channels[] =
MAX1363_4X_CHANS(10, MAX1363_EV_M);
-static struct iio_chan_spec max1363_channels[] =
+static const struct iio_chan_spec max1363_channels[] =
MAX1363_4X_CHANS(12, MAX1363_EV_M);
/* Applies to max1236, max1237 */
@@ -392,9 +392,9 @@ static const enum max1363_modes max1238_mode_list[] = {
MAX1363_CHAN_B(11, 10, d11m10, 23, bits, 0), \
IIO_CHAN_SOFT_TIMESTAMP(24) \
-static struct iio_chan_spec max1038_channels[] = MAX1363_12X_CHANS(8);
-static struct iio_chan_spec max1138_channels[] = MAX1363_12X_CHANS(10);
-static struct iio_chan_spec max1238_channels[] = MAX1363_12X_CHANS(12);
+static const struct iio_chan_spec max1038_channels[] = MAX1363_12X_CHANS(8);
+static const struct iio_chan_spec max1138_channels[] = MAX1363_12X_CHANS(10);
+static const struct iio_chan_spec max1238_channels[] = MAX1363_12X_CHANS(12);
static const enum max1363_modes max11607_mode_list[] = {
_s0, _s1, _s2, _s3,
@@ -433,9 +433,9 @@ static const enum max1363_modes max11608_mode_list[] = {
MAX1363_CHAN_B(7, 6, d7m6, 15, bits, 0), \
IIO_CHAN_SOFT_TIMESTAMP(16) \
-static struct iio_chan_spec max11602_channels[] = MAX1363_8X_CHANS(8);
-static struct iio_chan_spec max11608_channels[] = MAX1363_8X_CHANS(10);
-static struct iio_chan_spec max11614_channels[] = MAX1363_8X_CHANS(12);
+static const struct iio_chan_spec max11602_channels[] = MAX1363_8X_CHANS(8);
+static const struct iio_chan_spec max11608_channels[] = MAX1363_8X_CHANS(10);
+static const struct iio_chan_spec max11614_channels[] = MAX1363_8X_CHANS(12);
static const enum max1363_modes max11644_mode_list[] = {
_s0, _s1, s0to1, d0m1, d1m0,
@@ -449,8 +449,8 @@ static const enum max1363_modes max11644_mode_list[] = {
IIO_CHAN_SOFT_TIMESTAMP(4) \
-static struct iio_chan_spec max11646_channels[] = MAX1363_2X_CHANS(10);
-static struct iio_chan_spec max11644_channels[] = MAX1363_2X_CHANS(12);
+static const struct iio_chan_spec max11646_channels[] = MAX1363_2X_CHANS(10);
+static const struct iio_chan_spec max11644_channels[] = MAX1363_2X_CHANS(12);
enum { max1361,
max1362,
diff --git a/drivers/staging/iio/adc/spear_adc.c b/drivers/staging/iio/adc/spear_adc.c
index 64d630e..675c427 100644
--- a/drivers/staging/iio/adc/spear_adc.c
+++ b/drivers/staging/iio/adc/spear_adc.c
@@ -189,7 +189,7 @@ static int spear_read_raw(struct iio_dev *indio_dev,
-static struct iio_chan_spec spear_adc_iio_channels[] = {
+static const struct iio_chan_spec spear_adc_iio_channels[] = {
SPEAR_ADC_CHAN(0),
SPEAR_ADC_CHAN(1),
SPEAR_ADC_CHAN(2),
diff --git a/drivers/staging/iio/iio_simple_dummy.c b/drivers/staging/iio/iio_simple_dummy.c
index 155a49a..22eea83 100644
--- a/drivers/staging/iio/iio_simple_dummy.c
+++ b/drivers/staging/iio/iio_simple_dummy.c
@@ -63,7 +63,7 @@ static const struct iio_dummy_accel_calibscale dummy_scales[] = {
* This array of structures tells the IIO core about what the device
* actually provides for a given channel.
-static struct iio_chan_spec iio_dummy_channels[] = {
+static const struct iio_chan_spec iio_dummy_channels[] = {
/* indexed ADC channel in_voltage0_raw etc */
diff --git a/drivers/staging/iio/impedance-analyzer/ad5933.c b/drivers/staging/iio/impedance-analyzer/ad5933.c
index a8e51bc..e239ea9 100644
--- a/drivers/staging/iio/impedance-analyzer/ad5933.c
+++ b/drivers/staging/iio/impedance-analyzer/ad5933.c
@@ -108,7 +108,7 @@ static struct ad5933_platform_data ad5933_default_pdata = {
.vref_mv = 3300,
-static struct iio_chan_spec ad5933_channels[] = {
+static const struct iio_chan_spec ad5933_channels[] = {
.type = IIO_TEMP,
.indexed = 1,
diff --git a/drivers/staging/iio/imu/adis16400_core.c b/drivers/staging/iio/imu/adis16400_core.c
index 1f4c177..4ce9e3d 100644
--- a/drivers/staging/iio/imu/adis16400_core.c
+++ b/drivers/staging/iio/imu/adis16400_core.c
@@ -610,7 +610,7 @@ static int adis16400_read_raw(struct iio_dev *indio_dev,
-static struct iio_chan_spec adis16400_channels[] = {
+static const struct iio_chan_spec adis16400_channels[] = {
.indexed = 1,
@@ -740,7 +740,7 @@ static struct iio_chan_spec adis16400_channels[] = {
IIO_CHAN_SOFT_TIMESTAMP(12)
-static struct iio_chan_spec adis16350_channels[] = {
+static const struct iio_chan_spec adis16350_channels[] = {
.indexed = 1,
@@ -865,7 +865,7 @@ static struct iio_chan_spec adis16350_channels[] = {
IIO_CHAN_SOFT_TIMESTAMP(11)
-static struct iio_chan_spec adis16300_channels[] = {
+static const struct iio_chan_spec adis16300_channels[] = {
.indexed = 1,
diff --git a/drivers/staging/iio/meter/ade7758.h b/drivers/staging/iio/meter/ade7758.h
index ec202b4..1e11ad5 100644
--- a/drivers/staging/iio/meter/ade7758.h
+++ b/drivers/staging/iio/meter/ade7758.h
@@ -122,7 +122,7 @@ struct ade7758_state {
u8 *tx;
u8 *rx;
struct mutex buf_lock;
- struct iio_chan_spec *ade7758_ring_channels;
+ const struct iio_chan_spec *ade7758_ring_channels;
struct spi_transfer ring_xfer[4];
struct spi_message ring_msg;
diff --git a/drivers/staging/iio/meter/ade7758_core.c b/drivers/staging/iio/meter/ade7758_core.c
index 7014a00..6d3725a 100644
--- a/drivers/staging/iio/meter/ade7758_core.c
+++ b/drivers/staging/iio/meter/ade7758_core.c
@@ -661,7 +661,7 @@ static const struct attribute_group ade7758_attribute_group = {
.attrs = ade7758_attributes,
-static struct iio_chan_spec ade7758_channels[] = {
+static const struct iio_chan_spec ade7758_channels[] = {
.indexed = 1,
diff --git a/drivers/staging/iio/resolver/ad2s1210.c b/drivers/staging/iio/resolver/ad2s1210.c
index f313859..4ba4d05 100644
--- a/drivers/staging/iio/resolver/ad2s1210.c
+++ b/drivers/staging/iio/resolver/ad2s1210.c
@@ -575,7 +575,7 @@ static IIO_DEVICE_ATTR(lot_low_thrd, S_IRUGO | S_IWUSR,
AD2S1210_REG_LOT_LOW_THRD);
-static struct iio_chan_spec ad2s1210_channels[] = {
+static const struct iio_chan_spec ad2s1210_channels[] = {
.type = IIO_ANGL,
.indexed = 1, |
