drm/udl: Use ERR_CAST inlined function instead of ERR_PTR(PTR_ERR(.. [1]
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/err_cast.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
Signed-off-by: Dave Airlie
 drivers/gpu/drm/udl/udl_gem.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpu/drm/udl/udl_gem.c b/drivers/gpu/drm/udl/udl_gem.c
index 7bd65bd..291ecc1 100644
--- a/drivers/gpu/drm/udl/udl_gem.c
+++ b/drivers/gpu/drm/udl/udl_gem.c
@@ -308,7 +308,7 @@ struct drm_gem_object *udl_gem_prime_import(struct drm_device *dev,
 	/* need to attach */
 	attach = dma_buf_attach(dma_buf, dev->dev);
 	if (IS_ERR(attach))
-		return ERR_PTR(PTR_ERR(attach));
+		return ERR_CAST(attach);
 	sg = dma_buf_map_attachment(attach, DMA_BIDIRECTIONAL);
 	if (IS_ERR(sg)) {
