staging: vt6655: remove deprecated use of pci api
Author: Quentin Lambert <lambert.quentin@gmail.com>
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
  pci_dma_supported@p ( id, ...)
  pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
   when != pci_get_drvdata ( id )
   when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert
 drivers/staging/vt6655/device_main.c | 39 ++++++++++++++++++------------------
 drivers/staging/vt6655/dpc.c         |  4 ++--
 2 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/drivers/staging/vt6655/device_main.c b/drivers/staging/vt6655/device_main.c
index 0204ea5..e12caa8 100644
--- a/drivers/staging/vt6655/device_main.c
+++ b/drivers/staging/vt6655/device_main.c
@@ -540,12 +540,12 @@ static bool device_init_rings(struct vnt_private *pDevice)
 	void *vir_pool;
 	/*allocate all RD/TD rings a single pool*/
-	vir_pool = pci_zalloc_consistent(pDevice->pcid,
+	vir_pool = dma_zalloc_coherent(&pDevice->pcid->dev,
 					 pDevice->sOpts.nRxDescs0 * sizeof(SRxDesc) +
 					 pDevice->sOpts.nRxDescs1 * sizeof(SRxDesc) +
 					 pDevice->sOpts.nTxDescs[0] * sizeof(STxDesc) +
 					 pDevice->sOpts.nTxDescs[1] * sizeof(STxDesc),
-					 &pDevice->pool_dma);
+					 &pDevice->pool_dma, GFP_ATOMIC);
 	if (vir_pool == NULL) {
 		dev_err(&pDevice->pcid->dev, "allocate desc dma memory failed\n");
 		return false;
@@ -559,16 +559,17 @@ static bool device_init_rings(struct vnt_private *pDevice)
 	pDevice->rd1_pool_dma = pDevice->rd0_pool_dma +
 		pDevice->sOpts.nRxDescs0 * sizeof(SRxDesc);
-	pDevice->tx0_bufs = pci_zalloc_consistent(pDevice->pcid,
+	pDevice->tx0_bufs = dma_zalloc_coherent(&pDevice->pcid->dev,
 						  pDevice->sOpts.nTxDescs[0] * PKT_BUF_SZ +
 						  pDevice->sOpts.nTxDescs[1] * PKT_BUF_SZ +
 						  CB_BEACON_BUF_SIZE +
 						  CB_MAX_BUF_SIZE,
-						  &pDevice->tx_bufs_dma0);
+						  &pDevice->tx_bufs_dma0,
+						  GFP_ATOMIC);
 	if (pDevice->tx0_bufs == NULL) {
 		dev_err(&pDevice->pcid->dev, "allocate buf dma memory failed\n");
-		pci_free_consistent(pDevice->pcid,
+		dma_free_coherent(&pDevice->pcid->dev,
@@ -614,7 +615,7 @@ static bool device_init_rings(struct vnt_private *pDevice)
 static void device_free_rings(struct vnt_private *pDevice)
@@ -624,7 +625,7 @@ static void device_free_rings(struct vnt_private *pDevice)
 	if (pDevice->tx0_bufs)
@@ -689,8 +690,8 @@ static void device_free_rd0_ring(struct vnt_private *pDevice)
 		PSRxDesc        pDesc = &(pDevice->aRD0Ring[i]);
 		PDEVICE_RD_INFO  pRDInfo = pDesc->pRDInfo;
-		pci_unmap_single(pDevice->pcid, pRDInfo->skb_dma,
-				 pDevice->rx_buf_sz, PCI_DMA_FROMDEVICE);
+		dma_unmap_single(&pDevice->pcid->dev, pRDInfo->skb_dma,
+				 pDevice->rx_buf_sz, DMA_FROM_DEVICE);
 		dev_kfree_skb(pRDInfo->skb);
@@ -706,8 +707,8 @@ static void device_free_rd1_ring(struct vnt_private *pDevice)
 		PSRxDesc        pDesc = &(pDevice->aRD1Ring[i]);
@@ -775,8 +776,8 @@ static void device_free_td0_ring(struct vnt_private *pDevice)
 		PDEVICE_TD_INFO  pTDInfo = pDesc->pTDInfo;
 		if (pTDInfo->skb_dma && (pTDInfo->skb_dma != pTDInfo->buf_dma))
-			pci_unmap_single(pDevice->pcid, pTDInfo->skb_dma,
-					 pTDInfo->skb->len, PCI_DMA_TODEVICE);
+			dma_unmap_single(&pDevice->pcid->dev, pTDInfo->skb_dma,
+					 pTDInfo->skb->len, DMA_TO_DEVICE);
 		if (pTDInfo->skb)
 			dev_kfree_skb(pTDInfo->skb);
@@ -794,8 +795,8 @@ static void device_free_td1_ring(struct vnt_private *pDevice)
 		if (pTDInfo->skb)
@@ -841,9 +842,9 @@ static bool device_alloc_rx_buf(struct vnt_private *pDevice, PSRxDesc pRD)
 	ASSERT(pRDInfo->skb);
 	pRDInfo->skb_dma =
-		pci_map_single(pDevice->pcid,
+		dma_map_single(&pDevice->pcid->dev,
 			       skb_put(pRDInfo->skb, skb_tailroom(pRDInfo->skb)),
 	*((unsigned int *)&(pRD->m_rd0RD0)) = 0; /* FIX cast */
@@ -994,8 +995,8 @@ static void device_free_tx_buf(struct vnt_private *pDevice, PSTxDesc pDesc)
 	/* pre-allocated buf_dma can't be unmapped. */
 	if (pTDInfo->skb_dma && (pTDInfo->skb_dma != pTDInfo->buf_dma)) {
-		pci_unmap_single(pDevice->pcid, pTDInfo->skb_dma, skb->len,
-				 PCI_DMA_TODEVICE);
+				 skb->len, DMA_TO_DEVICE);
 	if (pTDInfo->byFlags & TD_FLAGS_NETIF_SKB)
diff --git a/drivers/staging/vt6655/dpc.c b/drivers/staging/vt6655/dpc.c
index 3c5b87f..b25ee96 100644
--- a/drivers/staging/vt6655/dpc.c
+++ b/drivers/staging/vt6655/dpc.c
@@ -140,8 +140,8 @@ bool vnt_receive_frame(struct vnt_private *priv, PSRxDesc curr_rd)
 	skb = rd_info->skb;
-	pci_unmap_single(priv->pcid, rd_info->skb_dma,
-			 priv->rx_buf_sz, PCI_DMA_FROMDEVICE);
+	dma_unmap_single(&priv->pcid->dev, rd_info->skb_dma,
+			 priv->rx_buf_sz, DMA_FROM_DEVICE);
 	frame_size = le16_to_cpu(curr_rd->m_rd1RD1.wReqCount)
 			- cpu_to_le16(curr_rd->m_rd0RD0.wResCount);
BtrLinux
Privacy Overview
