Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch replace pr_err/pr_info with dev_err/dev_infi, when
appropriate device structure is found.
Issues found using the following Coccinelle script. pr_err/dev_err was
substituted with pr_info/dev_info in the later case.
@r exists@
identifier f, s, i;
position p;
f(...,struct s *i,...) {
when != i == NULL
pr_err@p(...);
@rr@
identifier r.s, s2, fld;
struct s {
struct s2 *fld;
@rrr@
identifier rr.s2, fld2;
struct s2 {
struct device fld2;
identifier r.i, r.s, rr.fld, rrr.fld2;
position r.p;
-pr_err@p
+dev_err
+ &i->fld->fld2,
Signed-off-by: Haneen Mohammed
drivers/staging/media/davinci_vpfe/dm365_ipipeif.c | 2 +-
drivers/staging/media/lirc/lirc_sasem.c | 9 ++++++---
2 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/media/davinci_vpfe/dm365_ipipeif.c b/drivers/staging/media/davinci_vpfe/dm365_ipipeif.c
index ceeef18..17e105e 100644
--- a/drivers/staging/media/davinci_vpfe/dm365_ipipeif.c
+++ b/drivers/staging/media/davinci_vpfe/dm365_ipipeif.c
@@ -209,7 +209,7 @@ static int ipipeif_hw_setup(struct v4l2_subdev *sd)
/* Combine all the fields to make CFG1 register of IPIPEIF */
tmp = val = get_oneshot_mode(ipipeif->input);
if (tmp < 0) {
- pr_err("ipipeif: links setup required");
+ dev_err(&sd->devnode->dev, "ipipeif: links setup required");
return -EINVAL;
val <<= ONESHOT_SHIFT;
diff --git a/drivers/staging/media/lirc/lirc_sasem.c b/drivers/staging/media/lirc/lirc_sasem.c
index b9c53e2..0c9e082 100644
--- a/drivers/staging/media/lirc/lirc_sasem.c
+++ b/drivers/staging/media/lirc/lirc_sasem.c
@@ -172,7 +172,8 @@ static void delete_context(struct sasem_context *context)
kfree(context);
if (debug)
- pr_info("%s: context deleted\n", __func__);
+ dev_info(&context->dev->dev, "%s: context deleted\n",
+ __func__);
static void deregister_from_lirc(struct sasem_context *context)
@@ -182,10 +183,12 @@ static void deregister_from_lirc(struct sasem_context *context)
retval = lirc_unregister_driver(minor);
if (retval)
- pr_err("%s: unable to deregister from lirc (%d)\n",
+ dev_err(&context->dev->dev,
+ "%s: unable to deregister from lirc (%d)\n",
__func__, retval);
else
- pr_info("Deregistered Sasem driver (minor:%d)\n", minor);
+ "Deregistered Sasem driver (minor:%d)\n", minor);
if (tmp < 0) {
return -EINVAL;
kfree(context);
if (debug)
+ __func__);
if (retval)
__func__, retval);
else
