staging: unisys: virthba: remove extra parentheses around left bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise left shift operations.
The case handled is when resultant value is assigned to a variable.
The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/unisys/virthba/virthba.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/unisys/virthba/virthba.c b/drivers/staging/unisys/virthba/virthba.c
index ca89e76..2ad0c19 100644
--- a/drivers/staging/unisys/virthba/virthba.c
+++ b/drivers/staging/unisys/virthba/virthba.c
@@ -1534,7 +1534,7 @@ virthba_serverdown_complete(struct work_struct *work)
 		switch (pendingdel->cmdtype) {
 		case CMD_SCSI_TYPE:
 			scsicmd = (struct scsi_cmnd *)pendingdel->sent;
-			scsicmd->result = (DID_RESET << 16);
+			scsicmd->result = DID_RESET << 16;
 			if (scsicmd->scsi_done)
 				scsicmd->scsi_done(scsicmd);
 			break;
BtrLinux
Privacy Overview
