staging: rtl8188eu: replace memset(x,0,ETH_ALEN)
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
eth_zero_addr() is a wrapper function for memset if 0 is going to
be assigned to a mac address. The aforementioned function replaces
memset. In addition, linux/etherdevice.h was included as a header
since it is the file that define the inline function eth_zero_addr().
The changes were carried out using the following coccinelle script:
@header@
#include
@eth_zero_addr@
expression e;
-memset(e,0,ETH_ALEN);
+eth_zero_addr(e);
@eth_broadcast_addr@
identifier e;
-memset(e,\(0xff\|0xFF\|255\),ETH_ALEN);
+eth_broadcast_addr(e);
@linux_header depends on !header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@special_header depends on !header && !linux_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@custom_header depends on !header && !linux_header && !special_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8188eu/os_dep/ioctl_linux.c | 10 ++++++----
 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
index 58998f2..96c1c2d 100644
--- a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
+++ b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
@@ -32,6 +32,8 @@
 #include <rtw_iol.h>
 #include <linux/vmalloc.h>
+#include <linux/etherdevice.h>
 #include "osdep_intf.h"
 #define RTL_IOCTL_WPA_SUPPLICANT	(SIOCIWFIRSTPRIV + 30)
@@ -92,7 +94,7 @@ void rtw_indicate_wx_disassoc_event(struct adapter *padapter)
 	memset(&wrqu, 0, sizeof(union iwreq_data));
 	wrqu.ap_addr.sa_family = ARPHRD_ETHER;
-	memset(wrqu.ap_addr.sa_data, 0, ETH_ALEN);
+	eth_zero_addr(wrqu.ap_addr.sa_data);
 	DBG_88E_LEVEL(_drv_always_, "indicate disassoc\n");
 	wireless_send_event(padapter->pnetdev, SIOCGIWAP, &wrqu, NULL);
@@ -827,7 +829,7 @@ static int rtw_wx_set_pmkid(struct net_device *dev,
 		for (j = 0; j < NUM_PMKID_CACHE; j++) {
 			if (!memcmp(psecuritypriv->PMKIDList[j].Bssid, strIssueBssid, ETH_ALEN)) {
 				/*  BSSID is matched, the same AP => Remove this PMKID information and reset it. */
-				memset(psecuritypriv->PMKIDList[j].Bssid, 0x00, ETH_ALEN);
+				eth_zero_addr(psecuritypriv->PMKIDList[j].Bssid);
 				psecuritypriv->PMKIDList[j].bUsed = false;
 				break;
@@ -1028,7 +1030,7 @@ static int rtw_wx_get_wap(struct net_device *dev,
 	wrqu->ap_addr.sa_family = ARPHRD_ETHER;
-	memset(wrqu->ap_addr.sa_data, 0, ETH_ALEN);
+	eth_zero_addr(wrqu->ap_addr.sa_data);
 	RT_TRACE(_module_rtl871x_mlme_c_, _drv_info_, ("rtw_wx_get_wap\n"));
@@ -1037,7 +1039,7 @@ static int rtw_wx_get_wap(struct net_device *dev,
 	    ((check_fwstate(pmlmepriv, WIFI_AP_STATE)) == true))
 		memcpy(wrqu->ap_addr.sa_data, pcur_bss->MacAddress, ETH_ALEN);
 	else
 	return 0;
